Vestel / Luxor TV 50 inch UK Not reseting
  • loadedboyuk
    • Feb 2014
    • 26
    Hi people,
    I have not posted in a while glad to see the forum is still going strong
    I ahve a 50 inch luxor branded TV, it works well but it will not let me reset / return and store the updated TV channels.
    it works fine while powered on BUT...
    Every time I switch it off (stand by or mains) the channel lists reverts back to the old channel listings.
    I have reset it multiple times, tried to reset via the engineers menu, ran to see if any updates are alavilbe over the internet.
    its about 2 years old and "smart" (ish)
    I have attached the engineers info from the hidden menu if that helps.
    I see from other posts vestel might send out an update over USB
    At a guess the eeprom is not writing correctly when I make changes.
    If you can help that would be great
  • loadedboyuk
    • Feb 2014
    • 26
    Re: Vestel / Luxor TV 50 inch UK Not reseting
    LUX1050006/10 Vestel / Luxor TV 50 inch UK Not reseting
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      What is the result when you run the Diagnostic
      • loadedboyuk
        • Feb 2014
        • 26
        ALL SAYS OK
        apart from DDR Settings that says NOK
        I should also say, when I do a reset from either menu (service or retune) the TV looks like it will reset then goes to standby mode
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          DDR is "Double Data Rate Synchronous Dynamic Random-Access Memory" so you may well be correct that the channels are not being saved in memory.
          Do you have a well focused photo of your mainboard?
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            If this is your mainboard then it's really cheap to replace.
            • loadedboyuk
              • Feb 2014
              • 26
              Not had the back of yet as I thought it would be a software issue. replaced many boards in vestels before but never had this fault was intrested in seeing if i could fix it with a firmware flash or such
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                It's nothing silly like it's gone into "Hotel Mode"
                • loadedboyuk
                  • Feb 2014
                  • 26
                  not in hotel mode, it lets you tune and modify everthing just does not let you save the changes when it powers down
                  • Diah
                    • Feb 2013
                    • 6346
                    its firmware issue.. since its Vestel mb110 you can use the service menu USB Operation to download all profile and write back or change what ever you want.
                    how to:
                    on PC format USB drive fat32 and great file in name DownloadProfile.mb110 ( the extention should be as it written .mb110 )
                    inset usb at the Tv and turn on go to service menu and press USB Operation ..
                    all file you will got on the usb drive... u can zip them and upload over here to modified them to you..if you like..
                    also . downgrade the firmware will be a good idea
                    • loadedboyuk
                      • Feb 2014
                      • 26
                      here are the files. thanks
                      • Diah
                        • Feb 2013
                        • 6346
                        okay. i download them.... hold on to inspect them
                        Edit:
                        yours SW Profile all Normal. only you have Hotelmode was wrong encounter menu
                        delete all the file you download before.. just keep the file you generate with extension .mb110 and make folder on the usb with name ( profile ) and put the file attached after unzip inside profile folder and do the same way as you downloaded the files via service menu usb operation
                        • loadedboyuk
                          • Feb 2014
                          • 26
                          Edit:
                          Thanks for your help but it has not worked, TV is still acting in the same way
                          I added files to folder called profile, used the USB operations option in the service menu, when I retuned the TV and switched off it forgot all the channels again. it is not storing the changes I make.
                          • Diah
                            • Feb 2013
                            • 6346
                            downgrade the TV firmware.. or write a core firmware.. this is Turkey language page they have core recovery firmware for MB110 register required or any turkey member over here can help you by downloading.
                            tools to read and modified Language / SW / HW profile of Vestel Main boards , and other one stand alone only for edit SW Profile attached too to any one need.
                            • loadedboyuk
                              • Feb 2014
                              • 26
                              thanks I will give it a go. very much thanks for your help
                              • loadedboyuk
                                • Feb 2014
                                • 26
                                this is driving me crazy, all the update and downgrades seem to work but even though the profile file says "HOTEL TV NO" when I boot the TV it says YES! and will not save the retune, or allow me to "reset" the TV from the TV tuning menu! a new board might be needed I think
                                • loadedboyuk
                                  • Feb 2014
                                  • 26
                                  after a few hours of messing around. I found a MB board that fitts from my stock of stuff.
                                  again thanks for your help but this seems to be the olny way round. the TV is up and running again now with a replacement board!
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    Sometimes when you make a change in the service menu you have to follow a specific pattern. It's not always just change from Yes to No but could be press some other button to save the change? Just a thought.
                                    • Diah
                                      • Feb 2013
                                      • 6346
                                      this what i found at your SW_profile.bin was wrong at hotel mode menu.. it counter 0x000005 i changed it to 0x000000.
                                      you can try edid the sw_profile with first attachment i put here.. under config find hotelmode.. and change it from TRUE to False and write it back to the TV... before you start to scann make hard reset
                                      • chefau
                                        • Jan 2020
                                        • 11
                                        • gbrie
                                        A little warning here. I have a polaroid with an identical board in (MB110) with microangelo + platinum firmware on.
                                        Mine's about 2.5 years old too, mine started acting up, same way, not saving stuff, then one day it just decided not to switch back on, just kept flashing the stand by light every time.
                                        I found a seller on eBay, after identifying the exact board needed, it cost me £11 + £3 p&p and about 5 minutes of time to replace it (Most of which was spent removing and putting screws in :-D ) and now I have a fully working TV again.
                                        It seem's these MB110's (From what I've read elsewhere) have very poor nand ram in the SPI's, I've since had someone do some test on the old board, and they confirmed the spi chip is shot.
                                        • masterm
                                          JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
                                          by masterm
                                          TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
                                          Problem with TV:
                                          - Netflix stopped working so i tried to do factory reset from the TV menu.
                                          - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
                                          - After waiting for some time, the TV went into a boot loop.
                                          - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
                                          04-30-2024, 03:03 AM
                                        • France_53
                                          Vestel tv, how to flip the image?
                                          by France_53
                                          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                          05-12-2024, 05:22 AM
                                        • odie34
                                          Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                          by odie34
                                          I am a hobbyist (not a professional) so please be gentle...
                                          I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                          I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                          02-18-2024, 09:11 AM
                                        • ictc
                                          Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
                                          by ictc
                                          I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
                                          Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
                                          The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
                                          02-25-2025, 12:15 PM
                                        • kotel studios
                                          ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
                                          by kotel studios
                                          Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
                                          Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
                                          I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
                                          12-14-2024, 10:48 AM
