Need help troubleshooting
  • rbtsmpsn
    • May 2020
    • 4
    I was referred to this forum to hopefully get some input with an issue I'm having with my tv.
    Sony XBR-65X810C
    Solid light colors have cloudy darker areas. Very noticeable on full screen solid colors, especially light colors. Whites have a bluish cast. All colors have a bluish cast. The attached photo is a pure white test image being played from YouTube. It's a bit exaggerated due to taking the picture with my phone. But you can see the dark areas and the blue cast.
    Any suggestions as to what I should look at?
    Thanks so much.
  • neilc6
    • Nov 2015
    • 1550
    Re: Need help troubleshooting
    Looks like this model uses the backlight led modules that turn blue. Large round flat lens with four black dots.
    https://www.shopjimmy.com/sony-svy65...br-65x810c.htm
    https://www.badcaps.net/forum/showthread.php?t=80139
    https://ap.community.sony.com/s/ques...language=en_US
    • rbtsmpsn
      • May 2020
      • 4
      I actually contacted Shop Jimmy thinking it was a backlight problem. I attached the picture when I contacted them. This is the reply I got from them:
      That's actually a pretty odd image to see. Looks like the backlights might be getting too much power. Typically we'd see an issue like this AFTER swapping out the LEDs, normally due to reflective sheets that sit on top of the LEDs not being correctly installed. Super weird to see this sort of issue so I'm not 100% sure what the cause might be.
      They suggested I post here for input.
        • 12276
        • U.S.
        Backlights turned blue from being over-driven, would be my guess if so they need replaced and the backlights NOT brightness need to be turned down as far as tolerable, some do current mods with resistor/s.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I would tend to agree that the leds are turning blue as said above.
          • rbtsmpsn
            • May 2020
            • 4
            Thanks for the input.
            Much appreciated.
            • blues_spirit
              practical courses for troubleshooting pc motherboards
              by blues_spirit
              Hello from France,
              mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
              Do you think this is feasible for me? I...
              12-18-2022, 12:56 PM
            • silikon77
              Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
              by silikon77
              Hi!
              Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
              Found some advices watching youtube nad came up with this:
              It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
              I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
              See attached picture.
              I tried a few combinations to block individual clock...
              01-02-2025, 02:26 PM
            • gcrezz
              GV-N2060OC-6GD REV 2.0 GIGABYTE video card troubleshooting assistance needed.
              by gcrezz
              The issue with this video card is the HDMI port. Specifically on pin 19 (Diode checks on all other pins are normal). When i do a diode check on it from the pin on the board itself, I have nothing. There is also no short on the pin. Resistance reads about 200k. Normally on any HDMI pin 19 I would expect some voltage drop anywhere from .5v to 1.2v but here, I have nothing. The card is operational and can be used via the displayPort ports, but not through the HDMI. Attached you will find the pdf schematics for the card on page 22. I have verified that all of the resistors on this line before the...
              07-25-2024, 09:49 AM
            • CrewmanRedShirt
              Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
              by CrewmanRedShirt
              Hello all,
              As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
              07-13-2024, 11:02 AM
            • Zippie
              Troubleshooting Old Chiefmax 650Watt ATX Switching Power Supply
              by Zippie
              I’m looking for some advice troubleshooting an old Chiefmax 650w power supply in a PC, if it’s advisable to dig into it.
              Worst case I can replace the PSU, I’m just interested in learning the troubleshooting process. However, it’s out of my area of expertise and I could use some direction.
              During PC operation I heard a loud pop noise, like a cap gun and the tower lost power.
              Initially there is no power output 3.3v, 5v, or 12v when jumping the power on pin to ground. Also, no fan power.
              Opening the PSU the only things visible initially...
              03-07-2024, 07:58 PM
