Gentlemen , I have an Lg plasma tv with two intermittent verticle lines that come and go, Is this a tab bond issue? Is it worth tearing panel apart to try and temporarily fix, or just part tv out. Boards are in great working condition, and hard to find.
Lg 60 PK750 plasma tv
by xNOTxHello 👋 I have a tv with these red lines. I've tried cleaning and re-seating the ribbon cables but no luck! Tried all 4 on the LJ92-01485 board and on the bottom of the panel. Do you guys think it's the board?|
[Edit] I don't know why the thumbnails aren't linking to the full images, but here is the gallery. https://postimg.cc/gallery/WZcFzyf
by ArMaaN376Hello,
I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
Opened TV cover & observed foll
a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
How to confirm Y -Buffer board... -
by jm1234Hi,
anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
I checked that board for any obvious faults... -
by KYBOSHPicked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
No picture but you hear the TV static (white noise) playing loud and clear.
The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
But it seems they didn't get too far and just left it.
When I first took a look I was amazed at how pristine the inside looked.
Its as if the TV had been in a time capsule.
Caps looked like they were just pulled off the self.
Copper coils had no sign of corrosion on... -
by chazhThis is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,... - Loading...
