Another Panasonic TX-P42U30B no picture, green power led on constantly
  • ps2000
    • Apr 2020
    I did find a few of these in the search but seemingly not with my exact symptom.
    We noticed some strange colours on the screen for a while but once "warmed up" it was behaving.
    Now it will only show the green power light. On power up the green light does five rapid flashes (green not red) then goes to steady green and remains there. No response to the remote.
    Going through all the threads here, my first instinct was a bad SN board - suspecting the failure of the components due to poor earth that is well documented on here, but a couple of threads suggested that as I don't have the red flashing codes, it might be the A board.
    Changed the A board. Symptoms are unchanged.
    Thanks to someone on here I downloaded the service guide - this has a troubleshooter that talks about the LEDs on the SN and SS boards. Neither of these boards has any LEDs that I can see.
    My SN board is TNPA5349. I am considering ordering a refurbished replacement as I don't think I am competent enough to do board level component changes and there appear to be mixed outcomes anyway.
    Is there anything else I should be checking? Does anyone have a picture of a TNPA5349 with the led illuminated or where it is or know why mine aren't there or aren't working?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Another Panasonic TX-P42U30B no picture, green power led on constantly
    You can check the board as follows
    https://www.youtube.com/watch?v=uIyHr13b5w8
    • ps2000
      • Apr 2020
      Thanks Dick - I checked it and the board is short circuit as are those surface mount devices - I will order a new board - just slightly worried in case there are other faults but I guess that's the gamble I have to take when I have no real idea what I am doing. There was another thread that asked about the LEDs with no answer - maybe they are on a later version of the board or something.
      • FZG
        Panasonic AG-1000B VHS player with bad picture quality
        by FZG
        Hello!
        I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
        Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
        I want to know, is this something that could be solved by recapping or is the video head likely gone?
        Also, what mechanism is this?
        Any feedback is appreciated!...
        05-06-2024, 07:16 AM
      • Bazfletch3
        Panasonic TH-65FX800A backlight LED's working but picture is very dark
        by Bazfletch3
        Hi all
        While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
        I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
        From there I envisaged that the backlighting wasn't working, however...
        01-08-2024, 10:18 PM
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
      • CoolJc
        Panasonic TX49DX650B no picture
        by CoolJc
        Panasonic TX49DX650B - intermittent have sound & backlights but no picture, got LT feed to T-con fuse, tried a T-con board from Ebay but got permanent no picture with that so it got sent back,
        Guessing it must be a T-con or Main board problem - anyone experienced (and cured) the same fault?
        09-14-2022, 12:40 PM
