SONY KD-43x8305c
    • 31068
    SONY KD-43x8305c
    need a service manual and maybe some firmware dumps.
    customer says it's in a boot-loop and 2years old shouldnt be enough for bad caps!
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: SONY KD-43x8305c
    Is there anything in this that can help you.
    https://www.sony.com/electronics/sup...icles/00165623
      • 31068
      thanks - i'll pass this along
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        It will be interesting if it's successful.
          • 31068
          well the tv is important to the owner because it belonged to a family member who died!
          so time/parts are not an issue - just finding what needs to be done!
          • nomoresonys
            • 12206
            • U.S.
            Did you try a firmware update?
            • nomoresonys
              • 12206
              • U.S.
              Not sure where you are but that's the results for I believe it said Belgium and France or it's in French or sum such, can put other countries in there in the drop-down menu: https://www.sony.be/fr/electronics/s...d-/kd-43x8305c
                • 31068
                well the problem from what i'v heard is that it resets before you get a chance to factory-reset or upgrade the thing!
                i asked him to take a photo of the psu - i'm not expecting bad caps on such a new tv, but who knows.
                gota be worth a look!
                i have not seen the tv yet because the guys family have bought into the "lockdown" hype.
                • unimatrix93
                  Sony KD-43X8307C bootloop
                  by unimatrix93
                  Dear community,
                  I came with this Sony set with a bootloop problem. Maybe you can help me out.
                  The Sony logo appers, the android OS starts to load, then freezes, then reboots.
                  So this TV set is stuck in a bootloop, the first thing comes to my mind is a faulty EMMC, but I couldn't find anyone with a programmed replacement IC or a working motherboard that doesn't cost a fortune.
                  I Only have a CH341A sadly, so I can't flash it.
                  I made some video of the original symptom, when you plug in the TV.
                  And I also made...
                  08-16-2023, 01:27 AM
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
                • rascao
                  iMAc A1418 Board 820-00034 some kind of bootloop
                  by rascao
                  I have a iMac A1418 board 820-00034, the problem is when the board is cold i can get to the mac os log in for like 1 min and then start the bootloop, but is a fast bootloop sometimes i can just see the apple logo for 1 sec and keeps doing it until i un plug the power, if i try to turn on again the bootloop continues, if i let the board un plug for 15 or 20 min i can turn on again and log in on Mac os but the bootloop start again under 1 min.
                  I try to get to the recovery and i can, when try to install a new mac os it starts loading the usb and then start the bootloop,...
                  10-17-2024, 02:33 AM
                • dkneyle
                  Sony KDL-46HX850 Can't upgrade/update firmware
                  by dkneyle
                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                  09-25-2024, 10:44 PM
                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 05:27 AM
