Sony XBR-65X850E - has standby 3.3V, but won't power on - no status lights
  • nomoresonys
    • 12328
    • U.S.
    Re: Sony XBR-65X850E - has standby 3.3V, but won't power on - no status lights
    Good work, probably should have just retested 753 in circuit after taking 752 out, 752 was probably making 753 test bad.
    • heathloder
      IT Enthusiast
      • Mar 2014
      • 45
      Just wanted to provide an update to this thread after finally receiving my Schottky diodes in the mail.
      Replaced D752 and re-soldered Q750A, and...
      It worked! The TV powered on normally and booted up as expected. So, just to confirm, the issue with this TV was the 150V 5A Schottky diode labelled D752.
      Thank you @nomoresonys, @R_J, @budm, @ngth82 and @brucetv for your assistance!
      • nomoresonys
        • 12328
        • U.S.
        Glad to hear it, thanks for the feedback, not always but sometimes it's just a diode.
        • frica
          • Nov 2017
          • 37
          • Spain
          +1
          • edmusic
            • Mar 2021
            Hello all, new to the page. I have the same issue with this unit. I checked the same diodes, they check out ok. Any help would be greatly appreciated!!
            • heathloder
              IT Enthusiast
              • Mar 2014
              • 45
              Hi Edmusic. My assistance won't be nearly as helpful as the others on this forum with more experience, but I can at least offer similar insight to what was offered to me.
              Realistically, the diode was not the first suspicion for failure on this TV. Without pictures of your boards or measurements on the LED strings/main caps/LED drivers, there isn't really a whole lot of help that can be provided.
              If you follow the steps from the beginning of this thread (i.e. start with post #2 where @ngth82 mentions 5 things you can perform/test), then you will be more likely to find the issue with your TV. My "aha" moment came when I literally removed the suspected failed diode and respective FET from the LED driver circuit, and the TV's behavior changed suddenly.
              Lastly, @brucetv mentioned earlier in this thread that he had several of these come in with either bad rectifiers or a bad LED: "Check D751A and Q750A on power supply and if they are fine replace those four rectifier diodes." and "We did one about 6 months ago. No error blink code but we did find one led shorted. We got luckier with the other two with diode replacement."
              That being said, I think I was just lucky it was only a diode on my TV. Your issue could be anywhere on that power supply board, without knowing anything else about the TV.
              Good luck!
              • edmusic
                • Mar 2021
                Thank you , appreciate your response. I found some corrosion on some components. Cleaned them and reinstalled the board. Well, the tv came back to life. I am excited.
                • heathloder
                  IT Enthusiast
                  • Mar 2014
                  • 45
                  That's incredible news, actually! Glad to hear that it didn't require any replacement parts. Thanks for reporting your solution back here.
                  • dcbw
                    PowerMac G5 ACBel 614-0303 buzzing
                    by dcbw
                    The PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
                    The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
                    Other info: API2FS34, ID 291, Date B0404
                    05-31-2024, 07:13 AM
                  • stvhop
                    HP1955L Buzzing noise & interference
                    by stvhop
                    Hello, This is my first post so please forgive me if I miss out some vital info.
                    I have a problem with my HP1955L monitor from 2005.
                    The first thing to say is that it is still basically working, ie the picture is fine.
                    However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
                    The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
                    11-07-2020, 07:13 AM
                  • reessi
                    Hanns-G HG281D - LCD Monitor - Low B/L voltage and loud buzzing...
                    by reessi
                    The pics are off the other really long thread as they are much clearer than my phone will do.
                    The fault:
                    In standby there is no buzzing.
                    After signal input and turn on, a loud buzzing is emitted from the main transformer, no backlight.
                    It is because the 24v line is at 21v irrespective of whether the inverter is plugged in. There is a picture on the screen.
                    If you wait long enough the buzzing stops and the 24v line changes to 24v and the inverter comes on.
                    I have checked every single cap on the psu and logic board by un-soldering...
                    07-05-2020, 05:23 AM
                  • Rab1
                    Ipad 8th gen logic board making buzzing noises
                    by Rab1
                    Just to ask what could possibly be causing the logic board to make low buzzing sounds? Thanks.
                    04-05-2025, 11:15 PM
                  • master_haze86
                    A1990 820-01814-A dead not charging - need help with diagnostics.
                    by master_haze86
                    Good day everyone,
                    Let me preface this with letting you know that I have a smalltime computer repair shop but do not have a lot of experience when it comes to board diagnostics. I am good at soldering etc but finding the issue if there isn't an obvious burnt component is not my strong suit.
                    The other day I got a customer come in with a macbook A1990 (motherboard 820-01814-A) that would not turn on and had previously been getting the warning message that the battery needed servicing. (Most folks seem to ignore that message, just like the check engine light in vehicles.)...
                    09-13-2025, 06:01 PM
