Samsung UN65JS8500 flashing led.
  • kbradio
    Replaced power supply board BN44-00834A and the relay would just keep clicking. The replaced the main board BN94-10155Y.
    The TV worked for 4 days and died same flashing LED. Replace main board again no change. TIA for any help.
  • nomoresonys
    • 12086
    • U.S.
    Re: Samsung UN65JS8500 flashing led.
    Try test #3 below, try to do it just as instructed..
    • kbradio
      Thank you will do and report back.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
      • ermals
        Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
        by ermals
        Hi all!
        I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
        1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
        2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
        3. I've checked voltages...
        08-01-2022, 10:35 AM
      • H34TO
        ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
        by H34TO
        Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
        06-17-2025, 07:17 AM
        09-07-2024, 05:50 AM
