Panasonic TH-37PE30 2blink error
  • satinser
    • Oct 2012
    • 214
    • uk
    Early made in Japan Plasma. Service manual states error blink 2 for this model is Driver 1.
    Checked for shorts on SC and attached upper and lower buffer boards as well as SS board but no shorts found.
    Beginning to wish I hadnt taken this one on it appears that a number of years ago someone else had posted a 2 blink error problem with the 42inch version of this set which ended nonresolved.
    Any ideas???
  • satinser
    • Oct 2012
    • 214
    • uk
    Re: Panasonic TH-37PE30 2blink error
    Just replying to my own post for future reference should anybody else have same problem in the future.
    Although no shorts found on on SC board went ahead and ordered replacemant board and when fitted corrected issue.
    • nervx
      Panasonic TH-42PZ800 8-blink error mystery
      by nervx
      Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
      Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
      04-08-2022, 05:19 AM
    • cloo
      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
      by cloo
      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
      After doing a factory reset this problem was gone and the picture was back to...
      01-06-2025, 06:02 AM
    • pixelcap
      Pioneer Kuro Pro 111FD 8 red blink error
      by pixelcap
      Pioneer Kuro Pro 111FD 8 blink red LED.
      I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
      So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
      based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
      10-06-2024, 11:26 PM
    • orbit417
      Panasonic Plasma tc-p55vt50 6 blink error code
      by orbit417
      Hi All,
      Thank you in advance for your advice.
      I have a Panasonic Plasma tc-p55vt50 that's about 9 years old and has just recently stopped working :-(
      I noticed that when I turn the tv on I hear a click then screen comes on for like half a second then shuts off and the led blinks 6 times.
      I did some googling and found several video's on trouble shooting all sorts of blink codes. I finally came across one that showed 6 blink error code but for a different model. It recommended disconnecting the SC board to determine if it was the A board or power...
      04-14-2021, 09:11 AM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
