Sharp Aquos LC-40F22E - Not switching on!
+ More Options
Posts
  • Rhothgar
    • May 2015
    • 109
    • United Kingdom
    Hi
    Been scratching my head on this for a couple of weeks now.
    Neighbour was throwing TV out and I said I'd have a look at it. He says I can have it if I can get it working.
    He tried changing capacitors on power board and ended up buying a replacement power board. No joy!
    So the symptoms are that there is NO Standby LED when the unit is powered. The control board beeps when the buttons are pressed. I've tried a service reset but couldn't find exact reset technique for this TV anywhere.
    If I unplug the inverter board, the standby LED comes on and flashes 5 times twice. (This is course might be telling me that there is an inverter fault...)
    I noticed one of the dual channel transistors had blown so replaced that and still on joy. There are some burn marks to the underside of the inverter.
    From memory, it was a few days ago, I think I was getting intermittent voltage to the inverter on connector PL802.
  • Rhothgar
    • May 2015
    • 109
    • United Kingdom
    Re: Sharp Aquos LC-40F22E - Not switching on!
    • R_J
      • 9535
      Check the transformer secondaries and compare them, I suspect one is going to be bad, likely the one that had the shorted fet.
      • Rhothgar
        • May 2015
        • 109
        • United Kingdom
        The ones on the inverter or the power board? The power board does seem intermittent?
        I never found a wiring diagram for the inverter board during my searches for information.
        How would I go about testing the transformers on the inverter please? Other issue is it states 1000V on the inverter and my DMM only goes to 600V. Any chance you could do a markup for me on the photo to show what goes where on the transformer input and output please?
          by sam_sam_sam
          03-31-2024, 02:12 PM
        • JFarm
          Sharp Aquos LC-46E77UN inverter testing
          by JFarm
          I picked this TV out of a trash pile. When I plug it in I can hear the relay on the power supply “click” almost immediately, and then 7 seconds later there is another “click” and the power/OPC LEDs start to flash: two pulses on the power LED, one on the OPC LED. I didn't notice any sign of life from the backlight, but more on that below.....
          The service manual () says this is a “DET_10V error: UR10V or A9V is not applied”, but after checking several voltages I believe the power unit is tripping off due to an overload as soon as the backlight tries to come on; this kills...
          03-21-2021, 11:10 AM
        • scubacamper
          Sharp Aquos LC-70C6400U Half Screen Dark
          by scubacamper
          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
          05-03-2025, 12:19 PM
        • sefoster
          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
          by sefoster
          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
          11-20-2022, 09:29 AM
          by sam_sam_sam
          07-01-2024, 06:34 AM
