Panasonic VHS/DVD Combi Question
+ More Options
Posts
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Hi does anyone know the difference between, Panasonic models DMR-EZ48 and DMR-EZ49, Both identical models, Same ports, Any Panasonic buffs out there, Thank you
  • R_J
    • Jun 2012
    • 9576
    Re: Panasonic VHS/DVD Combi Question
    DMP-EZ48V
    The region number of this unit is “4”.
    The unit will play DVD-Video marked with labels containing “4” or “ALL”.
    DMR-EZ49V
    The region number of this unit is “2”.
    The unit will play DVD-Video marked with labels containing “2” or “ALL”.
    There could be other differences, download the manuals and compare spec's
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • ngml
      Repair of an LG split AC system indoor unit PCB
      by ngml
      I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
      This indicates an error in the communication between the outdoor and the indoor unit.
      The outdoor unit is fine, so the problem is the indoor PCB.
      The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
      I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
      Does anybody have the schematics of this board,...
      02-01-2025, 12:55 PM
    • valvashon
      Repair Success! Middle Atlantic UPS2200R-IP
      by valvashon
      Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
      Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
      02-06-2024, 12:54 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • LEEDASH
      Panasonic Dvd Vhs combi
      by LEEDASH
      Hi all, Fault F498, On the dvd part of a, panasonic combi, Will not open the tray or function.
      12-02-2020, 01:35 PM
