Samsung PS42B450B1W Technical Help Please
  • Kevonwine
    • Feb 2020
    • Scotland
    Hello, while I am not as technically minded as most of you I'm no slouch and am at a loss to find a solution. Any advice you can offer would be greatly appreciated.
    TV was clicking and not operating
    I replaced the power board, sound but no image (start up sound normal)
    Replaced the x-sus board, no improvement
    Replaced the y-sus board, no improvement
    Fully tested the y-buffer, no issues
    Then I noticed the led on the logic board was only lighting up for 2 seconds and not flashing thereafter.
    The power board is putting power to both sus boards but only for the time that the led on the logic board is lit.
    My suspicion is that the power board was not tested by the supplier and has an issue
    Many thanks in advance,
    Kevin
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • ohren
    Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
    by ohren
    I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
    I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
    The models launched in 2018 and 2019 respectively....
    09-08-2023, 05:24 PM
  • ermals
    Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
    by ermals
    Hi all!
    I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
    1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
    2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
    3. I've checked voltages...
    08-01-2022, 10:35 AM
    09-07-2024, 05:50 AM
  • Asraf Atb
    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
    by Asraf Atb
    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
    01-27-2025, 05:02 PM
