Samsung UE55JU6050UXZG
  • Muenze
    • Feb 2020
    Saturday I have bought a Samsung UE55JU6050UXZG Screen which has a bad mainboard (the seller sais so).
    The Seller has tried to repair the tv at a samsung service, or other tv maintenance service and they analysed it, and told him they could do nothing for him, warranty was expired and they couldn't get a new main board.
    I removed the cover, plugged in the power supply, but without Mainboard and the backlight started working immediately.
    I made a video from my next try with mainboard, i think its better than my crappy english...
    Samsung Startup video
    Can you tell me by viewing the video which component you thing is bad?
    I already checked the capacitors on the power board, also i checked the voltages on the pins to the mainboard and they look really good.
    I was hoping (when I bought the tv), that it is just a broken capacitor or something like that, but it seems they are ok.
    I cannot check the t-con board but i think thats also ok.
    Can you tell me why the blue light on the tcon board goes of every ~30sec?
    I already ordered a used mainboard for this tv, at ebay.
    Thanks in advance
    Guido
  • Muenze
    • Feb 2020
    Re: Samsung UE55JU6050UXZG
    Have I formatted my thread in a wrong way or not used the correct thread title?
    I need help really bad
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      No backlights with the main board hooked up? And you said you have backlights without the main board hooked up. If you have a volt meter, check the BLon pin that goes from the main board to the psu. I am thinking bad main board here, since BLon is generated on the main board.
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • mrautom8
        Samsung TV UN75H6350AFXZC main board schematics?
        by mrautom8
        Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
        Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
        While relay is on, all voltage rails are present and steady (scoped) on main board.
        I love a good logic puzzle but getting lost without any schematics.
        No shorts on ANY capacitor main board.
        Thermal camera shows 3.3V inductor getting warm instantly but...
        10-19-2025, 06:32 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • Lee M.
        Samsung UN75RU8000FXZA bad main board?
        by Lee M.
        When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
        11-08-2023, 07:46 PM
