Burnt cap 8.7nF 2KV horizontal cap.
  • Wizard
    • Mar 2008
    • 2296
    Hi all, this is from RCA ITC222 chassis in D52W19B.... CL031 location. Once in awhile we're lucky to resolder this joint on this but unfortunely arcing ate up and fried the capacitor that I can't trust it to survive the warranty period of our repair (90 days) so anyone have this rattling around in their cubbyholes storage?
    RCA part number is 259321. My local supplier shows it as NLA, means run out of stock and will not restock due to RCA haven't asked for another run of parts produced (permanently). That's quite a departure from long availability for the RCA of this caliber. This TV is 2005 so Can't be so soon but this happened.
    So start digging!
    Cheers, Wizard
  • PlainBill
    • Feb 2009
    • 7034
    Re: Burnt cap 8.7nF 2KV horizontal cap.
    http://www.audiolabga.com/mal_cart/d...ml/259321.html
    (I'm not sure if this is legitimate information).
    And this seems to be the correct part.
    http://www.hbfelectronics.com/index...._string=259321
    PlainBill
    • Wizard
      • Mar 2008
      • 2296
      PlainBill,
      Last link is good but I wondered why this first link suggests 10nF for that part number which is for 8.7nF.
      Reason I ask about anyone to rummage through your part bins and see if you can come up with 8.7nF 2KV poly cap. So we don' thave to deal with across the border order from a reseller, instead from a person to another would be nice.
      I found a combination of caps (two caps) that adds up to close 8.76 but it reads on capacitance meter as 8.65-8.7nF using a 8.2nF and a blue ceramic 560pF. But I'm leery if that works. I used to cobble together multiple poly caps to get real close but not like this with a poly log and a coated 2KV ceramic.
      Cheers, Wizard
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        Originally posted by Wizard
        PlainBill,
        Cheers, Wizard
        the hv will just come out a bit low and the pic a bit wide.
        the proper one is availible at least.
        i remember this cap would go open in older ss sets and blow the neck off the crt.
        • Wizard
          • Mar 2008
          • 2296
          1. Minimum order is the issue, and suppliers who does have this are in USA and major suppliers (big 3 IIRC), are NLA, but smaller suppliers seems still stock some.
          2. border fee for one item. not worth the trouble.
          3. Boss is reluctant to use credit card.
          Besides this is 4 years old set and I'm troubled by RCA mangling it's reputation by killing off good TVs. CTC203/ATC113, PTK195 and ITC222 were the awesome stuff. That capacitor for ITC222 was wet towel thrown on a party.
          Their RCA LCD is poor in service if we ever manage to get parts for.
          Blown off CRT neck sure, that was few years ago. This was DTV306 chassis 61". That we had 2 year repeat trouble with it, what started it off was one CRT needed changed (This swapping CRT was a routine job with other sets of PTK195 and DTV306 and ATC221, ITC222, as well as other DTV306 (not many thank god!) sets with no issues and we carefully set them up properly except this said 61" and was a NEW CRT). Then set wouldn't track well along with other 2 CRT and kept shutting down intermittently, error codes is impossible to determine, then other 2 CRTs later. Then finally one CRT blew its neck off. Chassis inspected for any bad joints are not found.
          RCA had to send us a CRT after few months as RCA had to collect enough CRTs to rebuild with! And that was in 2006. Funny thing, that CRT is also used in other later chassis. Go figure.
          This is early chassis design that begun using 31.5/32KHz design with 2 fans that is capable of 1080 and first chassis to have scaler module. I deplore DTV306/DTV307 with passion. This is because of very strange, extremely complicated chassis design, arcane service menu (necessary when setting up replaced CRT so they are biased properly for tracking let alone convergence (!!) ).
          I once had to replace two fans on other DTV306 even those fans still spin freely but protective circuit was tripping because fans were not responding fast enough! I flicked them as soon as TV is turned on before shutdown trip take place and TV stayed up. Also fans were intermittently not spinning. RCA made mistake of not putting in a simple circuit that does "voltage bump" to accelerate fan spin. RCA simply started them at barely starting minimum voltage and fans were 24V, RCA was starting them up around 8V. Madness.
          Cheers, Wizard
          • Wizard
            • Mar 2008
            • 2296
            Thread closed.
            Luckily customer knew one other place (this other one we don't refer to because we use one different private tv shop whom we help each other and know well the guy but the customer didn't go there even we didn't told him either so have no prior knowledge. Ok, customer was able to get this part and gave this part to us and we successfully fixed this said TV. That's it. We still got paid for this repair. Decent labor cost.
            Cheers, Wizard
            • rstrube
              ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
              by rstrube
              Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
              Hi Everyone,
              I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
              Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
              Today, 01:37 PM
            • rstrube
              by rstrube
              Hi Everyone,
              Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
              Today, 12:19 PM
            • electomech-fixer
              First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
              by electomech-fixer
              I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
              I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
              09-15-2025, 01:42 AM
            • Ihandyrepair
              Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
              by Ihandyrepair
              Hi guys
              I just started fixing 4k TV few months ago. so I am still learning a lot
              I got this tv from friend complaint is ghosting or horizontal lines on image.
              never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
              then it started to show the ghosting white image.
              I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
              it has 3 thin small boards at the bottom of the...
              12-05-2022, 04:18 PM
            • dicky96
              Zotac GTX 260 burnt component - can anyone identify?
              by dicky96
              Hi guys
              This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
              This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
              Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
              I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
              The good phase...
              12-01-2021, 01:02 PM
