sharp lc32d42u power supply - DPS-178APA
  • metropical
    replied
    Re: sharp lc32d42u power supply - DPS-178APA
    Took some doing but there is always a piece of sacrificial Cat 5.
    I took a piece of wire from ground to the Q7907 collector.
    With TV on or off, 5v.
    So Q7926 is good?
  • R_J
    replied
    Use a piece of wire to connect the emitter to collector, There is only about 5 volts at those points, or take a piece of wire from ground to the Q7907 collector, that will also turn on Q7926
  • metropical
    replied
    I'll have to find me some better gator clips. It's pretty tiny on that Q.
    But, unplug PE on the power supply and with the tv on, check the voltage on J7915. It is 0 volts.
    This might take me a few days to find leads out here in the boonies.
    Prolly pick some up in the city next week.
    I'll be in touch.
    Thanks very.
  • R_J
    replied
    Originally posted by metropical
    1.923k Ω
    Ok good, so the PNL5V line is not shorted. Unplug PE on the power supply and with the tv on, check the voltage on J7915. If it is 0 volts, short the emitter and collector of Q7907 (the two outside legs) together and see if you get +5v on J7915. this will check if Q7926 is working.
  • metropical
    replied
    1.923k Ω
  • metropical
    replied
    OK. Will do.
  • R_J
    replied
    I don't have a schematic, The main board does have panel 5 volt detect line, It is possible that Q7907 or Q7905 are bad, And the main board is not seeing the PNL5V
    Since you are sure the fault is on the power supply, The other problem could be that some thing like C7922 is shorted, check the resistance from J7915 to ground
  • metropical
    replied
    Originally posted by R_J
    Even if the cap was shorted, the voltage drop across R7930 should not totaly kill the 3.3volt pnl pow control signal
    perhaps that accounts for post 25 above?
    I don't suppose you could post the schematic?
    It'd be useful to me to know what I'm looking at.
  • R_J
    replied
    I see now that C7921 is a surface mount on the under side of the board.
  • metropical
    replied
  • metropical
    replied
    All you need to do is lift one end of R7930, If THEN the voltage on PD,pin4 comes up, you might have a shorted component but I doubt that is the issue.
    Can that be done with the power board out of the TV, or does it need to be done under "load"?
    If that isn't the issue, what might other possibilities be?
    I would think it's the power board, as, like I said, I swapped supplies with another of the same and the other TV that was dead was fine.
  • R_J
    replied
    Thanks very. R_J.
    I do hear noise from the speakers.
    So change out both C7921 & Q7907? If I can find C7921.
    Is it a small or large cap?
  • metropical
    replied
    Thanks very. R_J.
  • R_J
    replied
    The service manual does not have the power supply schematic.
    Even If you don't have the panel 5 volts, the tv should work, you just won't have an image because all that would be missing is the +5 volts for the tcon and the panel. (SM page 49)
    Post #19 has pictures of this part of the circuit board
    Since you have BU5V, UR13 & UR10V I would say your power supply board is working properly.
  • metropical
    replied
    I have UR13v PE, pins 11,12 showing 12v.
    UR10v pins 8,7 is good.
    Funny, my SM doesn't even list Q7907 or C7921. But I did find Q7907 on the PCB.
    Ah, I see, my book doesn't have the PS parts list .... near as I can tell
    Can it be checked in circuit or only lifted?
  • R_J
    replied
    Do you have UR13v PE, pins 11,12 and UR10v 8,7 ?
    If the PNL_POW signal is being killed, there are only 2 components that will do that, either C7921 or Q7907 are shorted to ground
    Best I can do with paint, but this is the circuit
  • metropical
    replied
    OK. But as I said. 2 of the same TV. Swapped out the PS board and all is well.
    Something else occurs to me. That voltage, Pin4 on plug PD, isn't steady 0v. It jumps around too fast to see the top, stand-by or powered.
    Unlike the 5v pin which is quite steady.
  • R_J
    replied
    Then the main board is not sending the PNL_POW signal
  • metropical
    replied
    yes. all boards connected
  • R_J
    replied
    guess I missed RJs post.
    In any case, Pin 4 of Plug PD stays at 0v, in stand by or powered on.
    Same with Pin 3 on plug PE, 0v, in stand by or powered on.
    Is the main board connected?
  • caspian
    What Zener Diodes on a Linear Power Supply
    by caspian
    Dear members,
    I have a linear variable power supply with unknown brand name that I used for voltage injection.
    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
    In addition, I discovered that its zener diodes are defective.
    I can replace the burned transistors.
    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
    Therefore, I cannot replace the zener diodes.
    I do not want to test the zener diodes in a test circuit to discover their model or value.
    no schematics are available...
    05-26-2025, 12:38 PM
    by sam_sam_sam
    03-31-2024, 02:12 PM
  • Dvsr
    On M-Audio AV40 active studio speaker's two zener diodes get really hot.
    by Dvsr
    Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
    I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
    After replacing the caps I started testing out the speaker. It seemed...
    09-10-2025, 10:20 AM
    by sam_sam_sam
    07-01-2024, 06:34 AM
