LG 32LN575S No power Blown fuse.
  • Dragunov
    • Nov 2013
    • 49
    • Croatia
    Hello guys I have here a 32LN575S that died while it was in standby for a while... Opened it up and found that primary fuse was blown...
    I desoldered the fuse and soldered a copper wire over it (dont know how to say it in english but one wire thiny). Didnt pulg it in yet dont know if the wire is to thick.
    Can you please help me check what might cause this and how to test/repair it.
    I have a standard multimeter and i also found a service manual for LN57xx series.
    Pictures and a manual in attachment.
    Many thanks guys
  • R_J
    • 9535
    Re: LG 32LN575S No power Blown fuse.
    Don't do it, You have a blown resistor, R113, so I suspect a shorted transistor Q101 and maybe damaged ic101. I would also replace C103 (100µf/50v) capacitor
    • Dragunov
      • Nov 2013
      • 49
      • Croatia
      Q101 is MDF11N65B N-channel MOSFET when i connect source with a Gate in diode mode i get short (beep) as i can find on the internet it is faulty.
      R113 I have no reading in diode mode so its faulty.
      I cant find IC101 where is it? (did you mean IC102?)
      • jetadm123
        • 2169
        You should use resistance mode to read R113. Not diode mode.
        IC101 should under the board (green side).
        • Dragunov
          • Nov 2013
          • 49
          • Croatia
          R113 it doesnt matter it has a burned hole in its side (It should be Resistor: 0.25 Ohms 5%)
          IC101 Please check picture...
          I will try to find replacement MOSFET in junk at home can you please tell me what values i need to find so i can replace it...
          Thx
          • R_J
            • 9535
            The ic drives the fet gate. If the Drain shorts to Gate, it will supply full Dc (160~300vdc) to the ic. Check the resistors and diode on the gate, R107, R106, D103 and also R106 (when R113 opens it can supply full dc to r106 and open R106 and also damage the ic)
            The ic should be SC1S311A, It might be ok, but if it is not it will blow the fet again.
            R113 should be 0.15Ω
            • Dragunov
              • Nov 2013
              • 49
              • Croatia
              Uffff ok let me check the junk first and find a compatible replacement for that fat and then we will go from there...
              • Dragunov
                • Nov 2013
                • 49
                • Croatia
                I need to order a new transistor...
                I will order...
                2x MDF11N65B (one spare if it burns out)
                2x resistor red, green, silver, gold (check picture it should be 0.25 by calc)
                I did not check IC, R107, R106(dont know how to check them properly) if it burns out i will order them later... D103 is ok.
                What about that fuse is that wire ok?
                • R_J
                  • 9535
                  If you are ordering parts why not get a few fuses? I can see the resistor colors better in this picture so 0.25Ω it is. You can check the other resistors in circuit, R106 connects R113 to the current sense pin of the ic, if R106 is open the ic will not detect any current flowing through the fet and may not operate. If R107,R108 are open or if D103 is shorted you may not have any gate drive for the fet.
                  • Dragunov
                    • Nov 2013
                    • 49
                    • Croatia
                    Ok so on what do i need to set my multimeter and what readings should i get from R106, R107, R108 in circuit?
                    • R_J
                      • 9535
                      I can't make out the markings on the resistors on your board but I believe they are:
                      R106 220Ω use the 2K scale
                      R107 22Ω use the 200 scale
                      R108 100Ω use the 200 scale
                      D103 should check using "diode test" but may not check properly because of R106 & R107 so just make sure it is not shorted.
                      • Dragunov
                        • Nov 2013
                        • 49
                        • Croatia
                        Hmmmm im posting higher res picture of the area... now you can see values on them.
                        R106 No reading (because it is in circuit?)
                        R107 No reading (because it is in circuit?)
                        R108 says 100
                        D103 says 637 one way and the other no reading
                        • yokoono
                          • Apr 2010
                          • 481
                          220 = 22 ohms
                          101 = 100 ohms
                          221 = 220 ohms
                          • R_J
                            • 9535
                            I am sure you should get a reading on the resistors, even in circuit, The reading on the diode, is correct but I would expect a different reading if the resistors were good so I would look closely at the resistors, I suspect they are open.
                            This should help you:
                            • Dragunov
                              • Nov 2013
                              • 49
                              • Croatia
                              So what do i need to do?
                              • jetadm123
                                • 2169
                                If you see no reading for R106 and R107, remove them and check them out of circuit.
                                • Dragunov
                                  • Nov 2013
                                  • 49
                                  • Croatia
                                  Desoldered them still no reading...
                                  • R_J
                                    • 9535
                                    So the resistors are open, then I would be 100% the ic is bad. And don't forget R108.
                                    • Dragunov
                                      • Nov 2013
                                      • 49
                                      • Croatia
                                      Ok so now comes the difficult part... Find the right parts to order...
                                      Would be much apritiated if you could check with what i can replace...
                                      Q101 MDF11N65B http://elmatis.hr/Products.aspx?categoryId=445
                                      IC101 SC1S311A http://elmatis.hr/ProductDetails.aspx?productId=28802
                                      R113 0.25 Ohms 5% http://elmatis.hr/Products.aspx?categoryId=73
                                      R106, R107, R108 http://elmatis.hr/Products.aspx?categoryId=248
                                      • R_J
                                        • 9535
                                        The ic seems to be correct, I'm not sure which mosfet you are using?
                                        any 0.25Ω 1 or 2 watt should be ok, and for the source resistor (seems you have a choice of 0.22Ω) It should be ok
                                        you need to measure the size of the smd resistors on your board, 1206 are 3.2mm X 1.6mm
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                          by sam_sam_sam
                                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                          12-16-2023, 08:39 PM
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
