Sony XBR65X850F
  • Plurxtc1
    • Oct 2014
    • 136
    Sony XBR65X850F
    TV clicks on with a solid white indicator and clicks off with the indicator off.
    - CN6401 Socket (PS to Main) shows up 12V when clicks on then goes to 0V when clicks off
    - CN6801 Socket (LED + to Backlight) shows up to 90V then drops back to 70V even with the standby indicator off
    - CN6082 Socket (LED -) is just 0V
    - Backlight is good, I removed the panel and injected current into the LED+ socket to LED- and every section of the edge lit LEDs light up.
    Does anyone have the service manual to this TV? I know previous XBR models would flash a sequence indicating an issue.
    Re: Sony XBR65X850F
    You have 8 LED strings, so all -OUT 1 ~ - OUT 8 show 0V every time you turn on the TV if you leave the black probe of the meter on the chassis and Red probe on each one of the -OUT pin when TV is turn on?
    https://www.badcaps.net/forum/attach...9&d=1577573798
    According to the Voltage chart, the LED power supply Voltage is supposed to be able to put out 117V up to 1A.
    If you disconnect the LED connector CN6801, then keep the black probe on the chassis, Red probe on +OUT 1 then turn the TV on, how high does the Voltage jump up to before it goes back down to 70V? Repeat the same test on +OUT 2 ~ 4.
    You also need to report the Voltage on each pin of CN6401, YOU MUST PUT DOWN THE PIN NAME AND FOLLOW BY THE VOLTAGE READING FOR EACH PIN WHEN TV IS OFF AND WHEN POWER SWITCH IS ACTIVATED. We need to see what is there and no there on those pins.
    Please also upload good clear pictures of the whole backside of the TV showing all the boards.
    What is the history of the TV? Did the problem start by itself?
    BTW:"- Backlight is good, I removed the panel and injected current into the LED+ socket to LED- and every section of the edge lit LEDs light up." What is the apply Voltage and current? So you drive all 8 strings of the LED?
    Baords:
    https://www.shopjimmy.com/catalogsea...ny+XBR-65X850F
    • Carlos#2003%
      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
      by Carlos#2003%
      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
      02-15-2024, 07:52 PM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-06-2024, 05:27 AM
      Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
      This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
      09-06-2024, 05:30 AM
      Sony VAIO VPCEE3J1E/WI E Specification for Upgrade or Repair
      This specification for the Sony VAIO VPCEE3J1E/WI can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEE3J1E/WI boardview and VPCEE3J1E/WI schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
