Phillips LCD - Static on A/V source
  • caphair
    • Nov 2011
    • 1249
    Hello I was wondering if there was a way to clear up the static picture when using a/v input on this tv. It's confirmed that it's the tv itself as testing on others results in a clear picture.
    I've tried cleaning the terminals with fine sandpaper but there's no difference at all. Would it be a circuit issue?
  • R_J
    • 9534
    Re: Phillips LCD - Static on A/V source
    That looks like a bad cap on one of the regulator ic's, likely on the main board. It their output cap. goes bad, as in open, the ic can oscillate causing this type of interferfnce.
    • caphair
      • Nov 2011
      • 1249
      I only see one cap part of the av board. Bottom right. Would it be that?
      • R_J
        • 9534
        There are a couple caps on the board, top right (Digital Main), I would suspect C3608, the one next to the black coil . I see there are no screws in the power supply/inverter board, was the interference there before the screws were removed?
        I take it this is the same tv from this thread https://www.badcaps.net/forum/showth...t=67328&page=2
        • caphair
          • Nov 2011
          • 1249
          Yes same TV
          • caphair
            • Nov 2011
            • 1249
            So it would be the caps on the main board not the RF board or main PSU board?
            • R_J
              • 9534
              Is the problem only there when on tuner (R.F.)?
              • caphair
                • Nov 2011
                • 1249
                Hdmi is perfect as well as coaxial input. Only there with A/V. Haven't tried component source
                • R_J
                  • 9534
                  By A/V I will assume composite input or S-Video, So if hdni is ok, then the fault is not likely on the digital board (top right board). I would start by checking if you are missing a ground between the a/v board and the main/power supply board
                  If the problem is with the VIDEO input, check the trace for in the signal path, maybe there is a poor connection on one of the ribbon cables between the boards
                  If there is a poor ground for the video board, you will be picking up noise from the ccfl high voltage circuit which will interfere with the video signal.
                  • caphair
                    • Nov 2011
                    • 1249
                    Visually checking all connections to the a/v board. Solder joints all look good too. I tried removing the ribbon cable and cleaning the contacts but that didn’t do anything.
                    • R_J
                      • 9534
                      Try the component input, You can switch the TV input to component and just plug the source video into the green input, that should give a green only picture. and see if the interference is still there.
                      • caphair
                        • Nov 2011
                        • 1249
                        Actually tried that before and get no picture at all. Not sure if it's the source I'm using or not
                        • R_J
                          • 9534
                          Use the same source that is giving you the picture on the video input.
                          Have you tried the VGA input?
                          • caphair
                            • Nov 2011
                            • 1249
                            Yes it's the same source I'm using. No haven't tried VGA input. Do all these inputs use their own voltages or are they shared?
                            • R_J
                              • 9534
                              All inputs are switched and processed by ic3301.
                              • caphair
                                • Nov 2011
                                • 1249
                                I noticed this tv’s mains plug doesn’t have a ground plug. Would that cause noise? Though I doubt it would be designed without a ground plug without filtering noise through the inputs
                                • R_J
                                  • 9534
                                  Most tv's these days don't have a mains ground, That is not your problem, if it was, don't you think it would also effect the hdmi and rf input also.
                                  Have you tried installing the power supply/inverter screws to see if that has any effect on the interference?
                                  Any filtering in the a/c input circuit is to prevent noise coming OUT of the tv's switching power supply.
                                  • caphair
                                    • Nov 2011
                                    • 1249
                                    Ah ok. Yes having all screws on and tight causes no difference. I’m about to just order an ab to hdmi converter for $10 and call it done I think
                                    • R_J
                                      • 9534
                                      Don't you have the service manual for this tv? It sure looks like the video ground is not making contact, If you pull out the video plug so the rca ground is not connecting does it change the interference? I can't see why you can't get a video signal on the component input. that would also check a different input that comes from the a/v board
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        If I pull out the video plug where the ground isn't connected the interference does change but still not clear. No video signal when I try on component input. Do you think it's related?
                                        • Lvsitano
                                          Asus X532FL 3.2V at source and gate
                                          by Lvsitano
                                          I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                                          First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                                          I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                                          First...
                                          06-26-2024, 02:13 PM
                                        • Kanini Technology
                                          Lenovo V15 Password Clear
                                          by Kanini Technology
                                          Hello I Need to Clear this Bios Password
                                          LENOVO V15 IIL GS44D GS54D NM-C711
                                          I Write another to password cleared But Hdd Not detected
                                          So Pls Need to Clear this bios Password...
                                          06-28-2025, 05:21 AM
                                        • LarrySabo
                                          Samsung ProBook NP767XCM-K1CA battery connector replacment source?
                                          by LarrySabo
                                          Tonight I broke the battery connector on the motherboard of this laptop and need to source a replacement. See pictures. The marking seems to read B6u. The sticker on the motherboard reads TCZRFN6X00230 P03AJD BA92-20746B 06 29. If someone could suggest a proper part number and source, I would be very grateful....
                                          12-04-2024, 09:10 PM
                                        • Imdeksn99
                                          ASUS fx505gt rev 2.0a bios request clear ME
                                          by Imdeksn99
                                          Need a bios laptop turn on but no display
                                          its 8Mbits Files
                                          bios is
                                          W25Q80EW 1.8V 8M-BIT​
                                          NEED HELP GUYS
                                          OR PLEASE CLEAR ME for me thank YOU
                                          11-24-2024, 02:52 AM
                                        • tofik
                                          MOSFET equivalent K8A60DA
                                          by tofik
                                          Hello guys,
                                          I have a shorted MOSFET K8A60DA with the following characteristics:
                                          Type Designator: TK8A60DA
                                          Marking Code: K8A60DA
                                          Type of Transistor: MOSFET
                                          Type of Control Channel: N -Channel
                                          Maximum Power Dissipation (Pd): 45 W
                                          Maximum Drain-Source Voltage |Vds|: 600 V
                                          Maximum Gate-Source Voltage |Vgs|: 30 V
                                          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                                          Maximum Drain Current |Id|: 7.5 A
                                          Maximum Junction Temperature (Tj): 150 °C
                                          Total Gate Charge (Qg): 20 nC
                                          Rise Time (tr): 25 nS
                                          Drain-Source
                                          07-19-2023, 05:18 AM
