Samsung UN78JU7500FXZA 8 blinking light code
  • baleman2
    • Nov 2019
    • 20
    For the first time in 4 years I unplugged my Samsung TV last evening to plug in a ROKU.
    TV is wall mounted. To clean up some loose hanging cables, I slid my TV about 8 inches to the left of its original position in order to give me a bit more space. My wall mount allows for this.
    I unplugged the TV from the wall outlet before doing this. I mounted my Dish TV box to the wall, my Samsung "oneconnect" to the wall, and used some plastic wire ties to bundle up my loose cables. Everything was plugged back in as before to the "oneconnect", Dish TV box, etc.
    After plugging the TV back in to the wall outlet, the TV will not power on. The red light is on at the bottom right of the TV. A push on either my Dish TV remote power button or my Samsung Smart Hub power button produces the following blinking light sequence:
    1) Solid red light after plugging in to the wall outlet.
    2) Pushing the power button on the remotes causes 2 rapid blinks of the red light for 4 successions, i.e., a total of 8 blinks.
    3) Solid red light after the 8 total blinks.
    I've taken the TV down and removed the back panel so that I can look at all the boards, but am unaware of any testing that I should attempt.
    I have no problem working with electronics. I'm an IT manager and am accustomed to complete computer repair/rebuilds/board replacements.
    I'm hoping someone can help me avoid the cost of a serviceman's repair.
    Please advise
    Re: Samsung UN78JU7500FXZA 8 blinking light code
    Lets start by uploading good clear pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with.
      • 12146
      • U.S.
      Start with simple reset, unplug tv hold in power button for 30 seconds release, plug tv back in and try it, leave all other devices unplugged dvd player etc. til you get the tv going.
      • baleman2
        • Nov 2019
        • 20
        Am uploading an overall view of the back of the TV. Also, individual pics of the different boards.
        TO nomoresonys: I've spent the last several hours using the "standard" reset processes, i.e., all the ones that I could find on GOOGLE.
        PICTURES TO FOLLOW.
          • 12146
          • U.S.
          Ok, check your voltages #3 below, try to do it just as instructed.
            • 12146
            • U.S.
            Should also be able to test powerboard and backlights, with tv unplugged from power, unhook cable from powerboard to mainboard, leave it unhooked, plug power cord into powerboard, see if backlights come on and stay on.
            • baleman2
              • Nov 2019
              • 20
              Guys:
              My computer shows the pictures have been uploaded, but I don't see them yet.
              • baleman2
                • Nov 2019
                • 20
                Hopefully, pictures attached.
                • baleman2
                  • Nov 2019
                  • 20
                  To: nomoresonys
                  Last picture of main motherboard is getting uploaded now.
                  I've watched the videos attached to your post relative to testing. I have no problems determining different boards on a computer; but, I'm a novice when it comes to the boards shown in these pictures.
                  Can you highlight one of these pictures so I'll know what to test?
                    • 12146
                    • U.S.
                    Pictures are a little blurry looks like connector CNM803 on the powerboard which you have pictured there is the one you want to test, see the legend/map for expected voltages?
                      • 12146
                      • U.S.
                      Be VERY CAREFUL what you touch on the HOT/DEADLY side of the powerboard, that connector is on the cold side.
                      • baleman2
                        • Nov 2019
                        • 20
                        I don't want to make any mistakes here, either. I'm going to send better pics of these connectors.
                        This is CN9003 - at top left of Power Board. I seen no voltages in the legend associated with it.
                        More Pics to come.
                          • 12146
                          • U.S.
                          That's not the one were wanting to test first.
                            • 12146
                            • U.S.
                            Is there a CNM803 on your board?
                            • baleman2
                              • Nov 2019
                              • 20
                              This is CNM803 - at top left of Power Board just under CN9003.
                              I see no legend of any kind associated with it.
                              • baleman2
                                • Nov 2019
                                • 20
                                This is CNL802A - at top right of Power Board. Legend is there, but now what I would expect to see for voltage readings????
                                • baleman2
                                  • Nov 2019
                                  • 20
                                  This is CNL802B - located just under CNL802A. Again, legend is there but not what I'd expect to see for voltage readings.
                                    • 12146
                                    • U.S.
                                    Find CM891 typical round capacitor, the legend/map should be next to it.
                                    • baleman2
                                      • Nov 2019
                                      • 20
                                      I've only found one labeled CA851 and am sending pic of it. I'll keep looking.
                                      • baleman2
                                        • Nov 2019
                                        • 20
                                        Found it - pic to follow. Don't give up on me.
                                        • matty24
                                          Samsung UE50MU6172 - red light blinking
                                          by matty24
                                          Hello. I have problem with Samsung UE50MU6172.
                                          TV won't turn on, red standby light is blinking.
                                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                                          Main board BN41-02568B (BN94-12530E)
                                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                          03-02-2025, 08:57 AM
                                        • Fergal22
                                          Samsung UE40F5300AK blinking red light
                                          by Fergal22
                                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                          Any help would be appreciated...
                                          02-02-2023, 09:19 AM
                                        • norbiszoke
                                          Samsung 50AU7172, only blinking red light
                                          by norbiszoke
                                          We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                          Regards, Norbert!...
                                          04-17-2024, 06:54 AM
                                          09-07-2024, 05:50 AM
                                        • 3DDD
                                          Samsung UE46D6100 LED TV blinking red light indicator
                                          by 3DDD
                                          Hello, I have a Samsung UE46D6100. It cannot be turned on, only the red status LED flashes, the power supply part bn44-00458a gives an output of 5V(A), it is probably functional. I don't know where to look for the error, according to the video it should be a faulty mosfet. I found a mosfet marked WAAH, I don't know what it is. Can anyone help me?...
                                          02-20-2025, 12:51 PM
