Hitachi 55HDX99 Plasma Display won't turn on
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hey guys, recently I repaired a Hitachi 55HDX99 Plasma TV with help from you guys on this thread. https://www.badcaps.net/forum/showthread.php?t=75627
    The problem ended up being a shorted buffer IC on the upper buffer board.
    After the repair, the TV was working fine and we used it on and off for about 20hrs. However, the last time we were using it, the TV just turned off in the middle of watching a show. There was no power at all and the power button did nothing.
    Unplugging the TV and plugging it back in makes all the relays click and the power light starts flashing blue. After a couple flashes, a relay on the power board clicks and all power is cut. I tried disconnecting the upper and lower buffer boards one at a time to see if another chip had failed but this made no difference. The symptom is also different from the bad buffer chip.
    If anyone has any ideas on what to look at first I would appreciate it.
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • Yanleb
    Schematic or datasheet for Plasma TV buffer chip
    by Yanleb
    I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
    So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
    Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
    05-18-2022, 01:36 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • canadaboy25
    Hitachi 55HDX99 Plasma Powers on but no picture
    by canadaboy25
    Hey guys, I recently acquired a Hitachi 55HDX99 plasma TV that doesn't work. The TV powers on and eventually goes into standby which is indicated by the blue power led changing to orange. If I plug a VCR into it to keep it awake, I can feed an audio source in and it will play the sound no problem. The volume controls on the TV work as well so it is obviously just a display problem.
    I found the Hitachi service manual online which is also hosted on tom66's manual archive. Compared to the Panasonic service manual I had for the last plasma I worked on, this one is underwhelming to say...
    03-22-2019, 12:06 AM
  • canadaboy25
    Hitachi 55HDX99 Plasma Tries to turn on then shuts off
    by canadaboy25
    Unplugging the TV and plugging it back in makes all the relays click and the power light starts...
    03-26-2020, 08:11 PM
  • KYBOSH
    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
    by KYBOSH
    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
    No picture but you hear the TV static (white noise) playing loud and clear.
    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
    But it seems they didn't get too far and just left it.
    When I first took a look I was amazed at how pristine the inside looked.
    Its as if the TV had been in a time capsule.
    Caps looked like they were just pulled off the self.
    Copper coils had no sign of corrosion on...
    02-01-2023, 11:10 PM
