50PX950-UA screen flickers
  • sailnaked6842
    • Aug 2019
    Hi guys, long time listener, first time caller...I have a 50PX950-UA that was working but the main board went out according to the Toms Service Manual. Jumped the two pins and the test screen popped up and looked like it should. Fast forward a week and I get a main board from TVPartsToday which looked kinda bad...but not great. They said it worked and offered a full refund if it didn't so I popped it in and the tv turned on but the screen went to pink and the tv didn't respond to the remote or the touch bar and it has me kind of concerned something inside burned up. Fast forward to today and I receive another board from someone else and now the TV powers up but it flickers and you get all sorts of horizontal lines. If you have any idea what this is doing or where you'd start trying to figure out the issue let I'd appreciate it. Hopefully it's not scrap. Attached is a video of what it is doing. All voltages check out per Tom's Service Manual as well.
    https://imgur.com/a/LLNY3XW is a link to the screen issue. Sorry about the creepy legs in the video
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Re: 50PX950-UA screen flickers
    Thats a main problem or lvds cable is not proper inserted or small cable on the lvds is damage.....if evrythings looks well connected main problem no good
    • sailnaked6842
      • Aug 2019
      Nailed it, there's a board after the main board that was disconnected to do the main board test...apparently that strip wasn't plugged back in properly. Disconnected and reconnected it and it's good as new
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • aaabddoo
        Dell 3520 intel vga error when i instel vga intel driver The screen flickers need help pls
        by aaabddoo
        Dell Precision 3520​ intel vga error when Run the programl vga intel driver The screen flickers need help pls
        Sorry for the language
        06-15-2025, 02:42 PM
      • Capacitorial
        Philips 46PFL8007K/12 - Picuture flickers on half of the screen
        by Capacitorial
        Hello guys.
        I recently got a TV that has the following problems:
        1. Sometimes it has to be turned on and off a few times, to boot up. Sometimes it starts from the first try
        2. When it is running normally, the right side of the screen flickers. Sometimes it is just a square of transparent white maybe a 1/3 of the right half (top right)
        3. The flicker is also sometimes a square that is filled with lines
        4. I noticed that when the TV brightness is set to max, it flickers less. I think the Standard setting is the worst where it comes more frequent
        5. When it runs a few minutes it gets better,
        12-17-2023, 11:11 AM
