50PX950-UA screen flickers
  • sailnaked6842
    • Aug 2019
    • 3
    Hi guys, long time listener, first time caller...I have a 50PX950-UA that was working but the main board went out according to the Toms Service Manual. Jumped the two pins and the test screen popped up and looked like it should. Fast forward a week and I get a main board from TVPartsToday which looked kinda bad...but not great. They said it worked and offered a full refund if it didn't so I popped it in and the tv turned on but the screen went to pink and the tv didn't respond to the remote or the touch bar and it has me kind of concerned something inside burned up. Fast forward to today and I receive another board from someone else and now the TV powers up but it flickers and you get all sorts of horizontal lines. If you have any idea what this is doing or where you'd start trying to figure out the issue let I'd appreciate it. Hopefully it's not scrap. Attached is a video of what it is doing. All voltages check out per Tom's Service Manual as well.
    https://imgur.com/a/LLNY3XW is a link to the screen issue. Sorry about the creepy legs in the video
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Re: 50PX950-UA screen flickers
    Thats a main problem or lvds cable is not proper inserted or small cable on the lvds is damage.....if evrythings looks well connected main problem no good
    • sailnaked6842
      • Aug 2019
      • 3
      Nailed it, there's a board after the main board that was disconnected to do the main board test...apparently that strip wasn't plugged back in properly. Disconnected and reconnected it and it's good as new
      • Samunggg
        Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
        by Samunggg
        I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
        I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
        09-06-2023, 06:39 PM
      • madyoyo
        Samsung UE43J5500: Replacing main board by another model or screen size
        by madyoyo
        Hi everybody;
        The main board (bn94-09121q) on my UE43J5500 is dead. I can't find the exact same board for a reasonable price, but some other part numbers are pretty cheap, they are physically identical, and based on the bn41-0235 board
        Can i swap the bn94-09121q by another "letter", like a bn94-09121N, or even from anoter screen size?
        12-27-2022, 04:15 PM
      • aazjo
        A1502 screen only issues
        by aazjo
        I have a MBP A1502 (early 2015, 820-4924) with a screen that will not turn on. I have swapped screens with a cracked test screen and the computer boots and the cracked screen works for both backlight and image. The black/blank screen appears to do nothing.
        I have collected resistant data from the cracked screen connector pins and submitted to OBData server:
        1 PPVOUT_SO_LCDBKLT OL
        3 I2C_BKLT_SCL 9.97M
        4 I2C_BKLT_SDA 9.89M
        5 PP3V3_S0_EDP_R 79.10k
        6 SMBUS_SMC_0_S0_SCL 321k
        7 SMBUS_SMC_0_S0_SDA 323k
        8 EDP_BKLT_PWM ...
        11-04-2021, 11:46 PM
      • reset1986
        Msi gaming main ms16j51 black screen
        by reset1986
        hello everyone at the beginning the pc had power problems, the power led turned on for 4 seconds and then turned off, the charging works,
        there was no short and I found for a few seconds the 3.3 5v, 1v pch, 1.2 ram,
        I flipped the sr2c4 chipset upside down, now the main power turns on, the power LED stays on and the fan is spinning, but I have the black screen, it draws only 0.20A.
        I flashed the bios downloaded from the original site, but it doesn't change, advice?
        Link to schematic - https://www.badcaps.net/forum/troubl...d-electronics-...
        11-08-2022, 05:05 PM
      • maxim2511
        LG 55EC930V OLED - swich on swich of no screen
        by maxim2511
        My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
        Then I get an idea to take it apart and clean boards from dust.
        In side of Tv was not so bad, I take compressed air in can, and gently blow up.
        Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
        05-14-2021, 02:21 AM
