Philips 48PFA4609/98 Firmware needed
  • snsent
    • Nov 2010
    • 103
    • Malaysia
    Hi...
    Please help me to find bios (.bin) for my Philips TV 48PFA4609/98
    Thanks in advance
  • Daniel Larsson
    Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
    by Daniel Larsson
    My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
    I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
    During these seconds the function button is not working...
    08-13-2025, 10:29 AM
  • Daniel Larsson
    Firmware file for Marantz NR1501 needed
    by Daniel Larsson
    I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
    After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
    The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
    The content of these seems to be useless as far...
    05-23-2025, 04:11 AM
  • ahmedtou
    HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
    by ahmedtou
    help me please
    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
    I will share all the details with you, including the disc information.
    Code:
    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
    Current Profile: BD-R
    Disc Information:
    Status: Empty
    State of Last Session: Empty
    Erasable: No
    Free Sectors: 12,219,392
    Free Space: 25,025,314,816 bytes
    Free Time: 2715:27:17 (MM:SS:FF)
    Next
    08-27-2025, 08:49 AM
  • vlady carp
    Looking for Dump for P87C51SBPN (Concord Infinity Elevator)
    by vlady carp
    Hello, colleagues!
    I'm currently dealing with an issue while repairing a Concord Infinity elevator. The microcontroller P87C51SBPN used in the control board has failed, and I need the original firmware dump in .bin format to replace it with a new processor.
    What I've done so far:
    • Diagnosed the issue and confirmed the microcontroller is the root cause of the problem.
    • The original processor is beyond repair, and I wasn't able to extract the dump.
    • Reached out to the manufacturer (Savaria/Concord), but I haven't received a response yet.
    01-16-2025, 02:08 AM
  • re-atari
    Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
    by re-atari
    Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
    Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
    02-03-2025, 06:49 PM
