need a bin working FIRMWARE for SAMSUNG 32inch tv model number: UA32D5000PR
Samsung 32 need firmware
by DynaxSCHi,
I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
The behaviour is also really very strange, i.e.:- The disk shows always up in BIOS - so it is recognized, so far so good
- POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
by Robby-GrHi all,
I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
Additional issues:...11 Photos -
by GeckoGreenHi,
I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
Will you please help me get the [2D63]LOGIC.bin file for my TV?05-17-2025, 02:47 PM -
by sikocanHello,
I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts... -
by MireniaHi everyone,
I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
Voltages on the power supply board is okay. Backlight test is also okay.
I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
So I think my TV has exactly this issue.
Can someone please fix the dump?
And how do you do that?
As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you... - Loading...
