Fta Tuner?
  • ivtec
    • Dec 2008
    • 1967
    Fta Tuner?
    Hi guys anybody here understand FTA tuners,my deal is i have a Fta SAT receiver and when i made connections by mistake, connected a tv to the IF loop out thinking that would be for a tv but then i started to smell some electronic burning smell,the receiver continue to work as nothing happened but later i got a 8psk card for HD but i could never see any HD channels although i can see the TPs, SD are all good and the HD from the ATSC also work good, i suspect either the card or the tuner loop out, the tuner is bellow.
    http://www.serit.com.cn/en/main/prod....asp?ArtID=542
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Fta Tuner?
    If you mean you connected the port on the box that is supposed to go to the LNB on the roof to the TV.
    You are screwed from my understanding power is fed from the box through the coax to power the LNB. You injected power right into your TVs tuner.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: Fta Tuner?
      yup... find a small casket for the tuner
      sigpic
      (Insert witty quote here)
      • ivtec
        • Dec 2008
        • 1967
        Re: Fta Tuner?
        Why you say that, the receiver is still working good on QPSK ,i have 18vout of the loop,i can get HD but not through the 8PSK.
        • Takeatry
          Yet another Samsung QLED Boot Loop
          by Takeatry
          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
          10-04-2024, 02:57 PM
        • DXseekerMO
          Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
          by DXseekerMO
          I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
          As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
          09-15-2021, 05:15 PM
        • blaster_
          Samsung UE49MU6105K - boot loop, horizontal lines
          by blaster_
          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
          06-22-2022, 05:19 PM
        • Stefano Crivellari
          Lenovo Legion 5 (15ITH6H) kind of boot loop but not sure
          by Stefano Crivellari
          Hi, I wonder if anyone can help me fix my Lenovo Legion 5 (15ITH6H) laptop. Basically, after a windows update the computer would not boot anymore. When powering on the laptop the screen has no backlight and nothing would show up, using an external monitor did not help. However, the laptop would still spin up the fans and turn on the keyboard backlight. The keyboard backlight intensity function key would work and the power button led and the charging led are also working. I've tried every possible combination of key press and power button hold down time but did not change anything. At this point...
          01-14-2025, 03:49 PM
        • ferah831208
          HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
          by ferah831208
          I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
          12-07-2024, 04:02 PM
