Samsung plasma PS-50P96, BN44-00175A PSU
  • masaudio
    • 16
    • England
    I have a TV with a fault of not starting up every time,
    It is definitely a power supply board issue, I have found that all voltages work apart from the VS volts 200v rail.
    So the set shuts down and tries again.
    Even on the test bench with the PS-ON linked, its the same on the bench.
    I cannot find the fault, and sometimes it does work and the set runs perfectly.
    Mark.
  • masaudio
    • 16
    • England
    Re: Samsung plasma PS-50P96, BN44-00175A PSU
    OK just realised i wasnt connecting the VS on properly,
    Now i have that triggered, still no volts but green LED does 4 flashes.
    Mark.
      Can we see good clear straight shot pictures of YOUR board whole top and bottom side?
      • masaudio
        • 16
        • England
        • masaudio
          • 16
          • England
          There we go.. thanks, Mark.
          • masaudio
            • 16
            • England
            I have just been over the caps with an ESR meter, I found CX813, CX807, CS807, CQ810, CQ812 (all 47uf 50v) & CQ822 (4.7uf 50v)
            All reading low or compare, replaced with new ones.. fault still the same.
            I have tested every other cap and the only other one I replaced that was visibly blown was C8814.
            • howardc64
              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
              by howardc64
              • Prior owner tried a replacement main board. No difference.
              • Samsung 2x red blinking standby LED = panel fault
              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
              07-19-2025, 10:54 PM
              09-07-2024, 05:50 AM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
