Need FIRMWARE: RCA 55120RE01M3393LNA35-C1 MAIN BOARD FOR LED55C55R120Q
  • oz_13_ms
    • Jun 2019
    • US
    Hello all!
    This is my second post after recently finding this website while browsing for downloadable firmware referenced in the title. As the title states, I am looking for firmware for RCA 55120RE01M3393LNA35-C1 Main Board, which I am in the process of replacing. Can anyone help me?
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • tvguy12012012120
    Picture degrades over ~2–3 minutes (washed out / low contrast) – panel vs T-CON/FRC vs main board diagnosis help
    by tvguy12012012120
    I’m troubleshooting a Westinghouse WD55UW4620 with a strange, very repeatable failure mode and I’m looking for insight on whether this points to the panel itself, T-CON/FRC board, or mainboard.
    Any ideas as to what would cause these symptoms?
    Symptoms:
    • From cold power-on, picture is perfect.
    • After ~2–3 minutes, the image slowly degrades:
      • contrast collapses
      • colors wash out / look incorrect (greens especially bad)
      • image looks “milky” / flat
    • Turning the TV off for a few minutes fully resets it; behavior repeats almost exactly each time.
    • Internal
    01-07-2026, 03:30 PM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
