P-Vision 42" LCD PSU tripping 17PW16-2
  • angelos
    • Dec 2012
    • 573
    • South Africa
    HI Guys,
    I have recapped the entire PSU because there were bloated caps and that did not solve the problem since the power supply is still tripping. The standby 3.3V and standby 5V are both fluctuating up and down.
    I even unplugged the board and started it up with the same tripping but no luck, still the same. I have thought of purchasing a refurbished PSU but thought while i wait for it perhaps someone who know these PSU's can give me some pointers.
    PS: I have read previous posts but it did not help solve the problem.
    Many thanks
    Angelos
  • arizanotlari
    • Nov 2014
    • 158
    • Turkiye
    Re: P-Vision 42" LCD PSU tripping 17PW16-2
    https://yadi.sk/i/9vcwwNCBSFjiaA
    Flowchart. H meaning No. E meaning Yes.
    https://www.badcaps.net
    • angelos
      • Dec 2012
      • 573
      • South Africa
      Thanks, i will try to follow the turkish fault tree but it wont be easy. Like i said my standby 5 and 3.3V is tripping continously.
      • arizanotlari
        • Nov 2014
        • 158
        • Turkiye
        when unplug psu from mainboard, connect 5V to stby pin of psu. if all voltages are ok check mainboard for shortcircuit.
        google translate flowchart :
        When the pfc circuit is active, it should be 380 volts in c819. If there is any problem in the pfc circuit, it will be 310 volts in c819.
        The d824 feeds the pfc circuit. The ic802 supply voltage should be 12 volts in normal condition.
        r829 is the current sensitivity resistance of the pfc circuit. If r829 resistance fails, the pfc circuit goes into protection.
        ic828, lm317 linear regulator. ic828 is the vcc supply source of pfc and half bridge control. Check the vcc problem ic828.
        The vcc pin of the standby controller ic806 is fed from pin 1 of the tr803. operating voltage is between 12-19 volts.
        If the ic806 supply goes below 12 volts or above 19 volts, it enters protection mode.
        The icc7 half bridge controller's vcc voltage should normally be 12 volts.
        The tr805 input pin should be measured in normal condition at the dc resistor oscilloscope and 400 kHz 400Vpp square wave.
        If there is a problem in the 3.3 volt line, ic825 should be checked.
        The ic824 on / off switch must be between 3.3 volts standby and 3.3 volts power on. If there is a problem in the 3.3-volt circuit, check ic824.
        If there is a problem in the 5-volt line, check the Q832.
        If there is a problem in the 12-volt line, check the Q827.
        If there is a problem in the 24 volt line, the card enters protection. When switched to protection, the collector of Q802 will be 0 volts.
        If there is a problem in the 24 volt line, check the Q815 Q816.
        If there is a problem with the 5 volt standby line, check ic829.
        If there is a problem in the 33-volt line, the d821 should be checked.
        after a period of time the device goes to the booth: ic802 (fan7529) from the block to the controller voltage to come to the controller (450 volts) the device goes to protection
        installation and protection, running after warm-up or self-closing: c877 c878
        switch to stand or sometimes no standby: change r838 to 2.2 kiloohm
        fuse waste: tr806 tr802 tr801 q803 d824 d800 check l817
        stby3.3 volts: check ic825 tr803 l804, respectively. If the relevant materials are intact, check for 19 volts on the c801. If there is no voltage, replace the d807. If there is a voltage, check / replace the ic806 d823 ic801 Q831 Q833 Q834 d847 d854
        vcc12 volt no: Q824 l811
        vcc5 volt no: Q832 d845 d846
        vcc3.3 volt no: ic824
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
        • fharris1977
          Vizio D50u-D1 Dead Set No Standby
          by fharris1977
          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
          12-28-2023, 10:25 AM
        • Crystaleyes
          Samsung BN44-00259A standby question
          by Crystaleyes
          Hi all.
          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
          08-11-2023, 05:15 AM
        • psssst
          Yamaha TSX 120 Standby Problem
          by psssst
          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
          03-01-2024, 07:25 AM
        • ChristianBr01
          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
          by ChristianBr01
          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
          04-23-2025, 01:48 AM
