Sharp aquos 60" lc-60le644u (vertical lines and blurring)
  • Tonybronx
    • Mar 2019
    I have found out that the cause of the vertacle lines maybe.
    "tab driver failure / fault"
    i have been told there may be a fix for it by removing it, and getting more service out of my tv that is four years old. Is there a way for me to do this?
    Thanks for any advice.
  • scubacamper
    Sharp Aquos LC-70C6400U Half Screen Dark
    by scubacamper
    I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
    Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
    when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
    05-03-2025, 12:19 PM
  • sefoster
    Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
    by sefoster
    I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
    11-20-2022, 09:29 AM
  • jonah1024
    Sharp Aquos LC-40UG7252E LCD TV burn in?
    by jonah1024
    Hello!
    I'm a few days old into this TV screens repair universe so please bear with me.
    Recently, and all of a sudden my 40ā€ 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
    - I did the classic unplug and hold power button to discharge the caps but it didn't help.
    - I did a factory reset as well...
    07-16-2024, 04:23 AM
  • zoontz
    SHARP LC-70UD27U black and white lines
    by zoontz
    Wondering if anyone has addressed an issue with the SHARP 70ā€ LC-70UD27U having thin black and white lines running from left to right horizontally on the screen. I snagged this TV set from a neighbor since I have been successful in repairing numerous other TVs. I assume this probably happens to other TV sets and may have been addressed in another thread. If so please point me in the right direction.
    What I have tried so far.
    I have tested all HDMI inputs with the same results.
    I have checked for firmware updates.
    I have reset to factory settings.
    I have removed...
    07-09-2024, 05:50 PM
  • Tonybronx
    by Tonybronx
    I have been told there may be a fix for it by removing it, and getting more service out of my tv that is four years old. Is there a way for me to do this?
    Tonybronx is online now Report Post
    04-01-2019, 07:20 PM
