Lg curved oled 55ec930t not starting
  • Diah
    • Feb 2013
    • 6611
    Re: Lg curved oled 55ec930t not starting
    Originally posted by advancedservers
    there is also no 24VD power on connector p202 on the power supply
    i am confuse with your way to testing. let do it again.
    1- MB should always disconnected from PSU
    2- plug in the TV in wall socket... test if you have 3.5 V stand by on PSU.. yes.. continue
    3- plug it out from wall socket. and make short contact between STBY 3.5V to Power on pin. then plug it in wall socket. here you will hear the relay click , SMPS on PSU for 12 24 V should be working.. here on the PSU socket to MB no 12-24 V
    4- plug the set out from AC and add the third shot contact between STBY 3.5 and DRV-ON then plug it in AC here you can test 12 and 24 volts on the sockets ..
    again all these test MB should be disconnected
    • Diah
      • Feb 2013
      • 6611
      on things more. if you did the short contact between STBY and Power On, STBY and driver on and there no 24 volts while MB disconnected.. do it again and this time disconnect PSU socket to T-CON ... again always leave MB out from this test
      • advancedservers
        • Apr 2019
        • 18
        Hi Diah, Once again thank you for your help. Sorry for my confusing posts..
        1. Yes MB is disconnected from PSU
        2. Yes have 3.5v STBY
        3. I hear the relay click Connector P201 on PSU has the voltages below working
        12v
        24VS
        3.5v
        Connector P202 doesn't have 24v as expected.
        4. With the DRV-On connected to 3.5v connector P202 has 24v. No change in display though.
        • advancedservers
          • Apr 2019
          • 18
          Voltage test
          • Diah
            • Feb 2013
            • 6611
            Voltage test
            now clear.
            as your points 4 now we are sure PSU provide us what we need.
            same way of the connected STBY to Power on and driver ON. with out MB connected. T-CON should be connected to PSU. use car lamp Dual flame . to make load test of the PSU
            • advancedservers
              • Apr 2019
              • 18
              ok will do test now
              • advancedservers
                • Apr 2019
                • 18
                I used a 24v 3A Fan and is worked at full speed.
                • Diah
                  • Feb 2013
                  • 6611
                  i will apply for you A patent for Fan use
                  the Idea of Lamp are how much currents it will use not volts. in other way how many watts will add on the load circuit of the 24V. line.
                  yours Fan patent its just 0.2 or less w.
                  • advancedservers
                    • Apr 2019
                    • 18
                    ok point taken.. I will pick up bulbs today
                    • Diah
                      • Feb 2013
                      • 6611
                      good..
                      also please before use lamp test as you have MB in test disconnected.. only the short contact in place as you did before ...trace the 24v line on the T-CON driver side.. stating from the socket on it. the first components with Z mark label
                        You should check the cold resistance of the incandescent lamp to see how low it is, if it is really really low it will cause inrush current that may trip the protection circuit since cold resistance of the incandescent will be about 15 times lower than the Hot resistance.
                        • advancedservers
                          • Apr 2019
                          • 18
                          Hi Budm,
                          Will do. about 10 - 15 ohms be ok?
                            It that what it is as measured to be? How many Watts is these lamps rated at?
                            • Diah
                              • Feb 2013
                              • 6611
                              car lamps are standard. dual lot used by second and high light for 12 volts car. or one lit bulbs for 24V Truk, if use 2 lit 12 V just the lit pin with out chases in use- if one lit 24V then he will have one one pin only for lit and chases to use. recommended 2 lit as they will simulated the load of the screen and T-con
                              turn signal or brake with secondary light lamp lamp 12v with dual lit can be used too
                              • dataman
                                • Nov 2015
                                • australia
                                #35
                                Hi are there any results yet?
                                • advancedservers
                                  • Apr 2019
                                  • 18
                                  Sorry guys been super busy with work. I am now back on this project. I have the bulb to do the test with but I am unsure where to plug the wires into.
                                  from the manual
                                  Code:
                                  (8) Attach one end of the Jig to the 24V line from the SMPS.
                                  (9) Attach the other wire from the Jig to Chassis Ground.
                                  Tip: Cut the sharp end of a safety pin off and solder it to Each end
                                   of the wires coming from the Jig. Push one Needle end into any pin
                                  8-14 of CN7. Push the needle End of the other wire into any
                                  pin 1-7 of CN7.
                                  from what i can gather unplug CN7 from Tcon then put wires into cable from SMPS to tcon (while Tcon disconnected) into 8-14 and 1-7.
                                  • advancedservers
                                    • Apr 2019
                                    • 18
                                    Can anyone help?
                                    • Jayasiri
                                      • Nov 2019
                                      • Sri Lanka
                                      #38
                                      Hi, My tv has the same issue and I am very interested to know the final result / findings of your troubleshooting.. What was the issue? have you managed to start your tv?
                                      • bahramjon
                                        • Aug 2019
                                        • sdfws
                                        #39
                                        hi my tv haw same problem
                                        • trnrohit
                                          • Nov 2020
                                          • 5
                                          • India
                                          #40
                                          My Lg curved oled 55ec930t has same problem, when powered on it tries to start but clicks off. Need some solution.
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:40 AM
                                            Gigabyte AERO 14 OLED BMF-72EEBB4SO Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72EEBB4SO Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72EEBB4SO boardview and 14 OLED BMF-72EEBB4SO schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:38 AM
