Sony Bravia KDL-42EX440 - problem - turns off after switching on
  • Diah
    • Feb 2013
    • 6593
    Re: Sony Bravia KDL-42EX440 - problem - turns off after switching on
    my way to do any edge LED back light by replace them all
    1- with hot air gun from the down side of the strips heat them and took all out
    2- with shave plate scratch the LED strips more from right side and left side
    3 place solder on the old place and the new scratch with iron
    4- replace the new LED in place with finger press it at its place then with iron i heat the solder outside the LED, it will mild all solder of one side and the led i can feel it pressed down a little. same way to opposite side.
    • Diah
      • Feb 2013
      • 6593
      can you post photo of yours LED Back light socket on PSU .. ?
      you said each strip had 56 LED, this huge if they are not separated as groups. to be sure if they are 6 or 3 volts
      • zarko
        • Mar 2019
        • 14
        • Serbia
        Yes it is 56 LEDs in series per strip (one group).
        I tried LEDs with 3V at fIrst but I could not get them to shine.
        After that I tested LEDs with 6V, all LEDs are shining except 5 LEDs which are bad.
        I expected one LED to be bad. How come 5 LEDs were open connection?
        On PSU there are two connectors for LED back-light. Two pins per connector.
        Photos attached.
        • Diah
          • Feb 2013
          • 6593
          Photos attached.
          what are the label reading of the 2 caps near back light socket on PSU ?
          • zarko
            • Mar 2019
            • 14
            • Serbia
            Both caps are 10uF, 450V.
            • zarko
              • Mar 2019
              • 14
              • Serbia
              #26
              I have analysed those 4020 LEDs that are working fine.
              This is what I measured:
              Voltage applied:___| 5.5V | 5.75V | 6.00V | 6.2V
              Measured current:_| 20mA | 40mA | 60mA | 80mA
              Measured current is nor exactly the same for all LEDs, this is average value.
              I am thinking of switching to 2835 LEDs.
              I have found this LED in a local store but I am not sure if it would be suitable for LCD TV usage.
              https://store.comet.rs/Catalogue/Product/48222/
              • Diah
                • Feb 2013
                • 6593
                you are going with this thinking to damage the strips and it may cause damage your PSU. stay on original 4020
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  I wouldn't change the LED dimensions on an edge lit TV. The LEDs were chosen for a reason. They reflect their light down the inside of the acrylic sheet on edge lit TVs. Changing the LED width will upset those reflections.
                  • zarko
                    • Mar 2019
                    • 14
                    • Serbia
                    #29
                    Thank you Diah & diif.
                    I will stay with 4020.
                    I guess it is Aliexpress then.
                    • Elviscocho
                      • Jan 2021
                      • Dominican Republic
                      #30
                      I’m sorry for my bad English because is not my first language, but I want to know if you resolved the problem. I have the same issue on the same tv model and I want to be sure if it’s the led strips that are bad so I can order a new one and replace it.
                      • zarko
                        • Mar 2019
                        • 14
                        • Serbia
                        #31
                        Hello Elviscocho,
                        Yes, I resolved the issue. Problem was in the led strips.
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                        • JUCaESAl
                          Sony bravia KD-65AF9
                          by JUCaESAl
                          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                          10-20-2025, 04:03 AM
                        • PopsCaps
                          Sony Bravia KDL-40V2500 that will not power on
                          by PopsCaps
                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                          I do not hear any sound and I cannot see any backlight.
                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                          03-25-2025, 11:23 AM
                        • alegatorul
                          sony bravia kdl-43w756c, no power, no sound
                          by alegatorul
                          the charger brick has 19,2-19,3 vcc
                          changed the inverter board same result.
                          where should i start?
                          cheers
                          11-15-2025, 10:00 AM
                        • justin35
                          Sony bravia kdl-43w755c - boot loop
                          by justin35
                          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                          from what i read online it looks to be an emmc issue…
                          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                          i took out the board and say an samsung 16gb emmc
                          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                          i could try to put one instead of the 16gb one, but will it work?
                          where do i get the software from?
                          any help will be much appreciated!...
                          03-06-2024, 12:26 PM
