Replacement LG 6916L-190(2,3,4)A Back-light strip
  • diablo9987
    • Dec 2018
    • 6
    Hey I need a new back light strip for my LG 65LB7100 6916L-1902A but I am having trouble finding a replacement. The closest I could find looking through ebay is the 6916L-1776A which looks exactly the same but is not the same model number so i don't know what would be different or if it would work.
    So if any of you have any info on where to get a replacement (that can be shipped to Canada) or if the similar one I listed below would work it would be much appreciated.
    image of Strips
    image of my strips info
    Link to the similar strips https://www.ebay.ca/itm/12LED-1370mm....c100005.m1851
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • mc900fthanna
    Visio M70-C3 LED replacement strips
    by mc900fthanna
    So... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
    Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
    11-28-2022, 03:03 PM
  • anupkg1985
    Insignia NS-50DF710NA21 Replacement LED strips
    by anupkg1985
    I have this Insignia tv with most of the led's damaged. I'm not able to find the replacement LED strips for the same. The numbers marked on LED strips are -
    LB-GM3030-GJBETTY504XBBB19. Please find the photo for the same. Can somebody help finding replacement/equivalent led strips for the same....
    05-02-2022, 04:59 PM
  • smort
    Backlight Polkadarks
    by smort
    Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
    I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had...
    03-11-2025, 12:33 AM
  • Firentiosi
    1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
    by Firentiosi
    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
    The issues are as follows: the...
    11-27-2024, 12:33 AM
