Insignia NS-50LC240A13 questions
  • asel51
    • Jan 2019
    • 5
    My Insignia NS-50LC240A13 quit the morning after a night time electrical storm in our area. At first, it randomly popped up menus and changed options as if someone was changing settings with the remote. After a bit, the menu popping up would cease and it would operate normally for while, from 5 to as much as 30 minutes at time. After a few power on reset cycles, it would no longer turn on at all.
    I took it down, got the the back off and found no visible problems. The power supply was working (5VST at 5V, 12V rails OK) and the PON pin was at 2.95V - the main board was signally for the power supply to be on. The BON and PWM pins were low and the back light was off. To check the power supply and the back light, I pulled the cable from the main board and pulled PON, BON and PWM to 3.3V with an external supply and the back light came on. Thus the power supply board and back light are good.
    This TV uses the 569MF0801A model main board and has several LM1117 type regulators powered from 5VST, 5V and 12V. The output voltages of each of these measure what appears to be valid voltages; 3.3V, 2.5V, 1.8V and 5V for the tuner (via dropping resistor from 12V to LM1117 regulator). However, the temperature rise on the 3.3V regulator powered from the 5VST is noticeable. I pulled the main board off the TV and powered it from a 5V bench supply and the standby rail pulled about 650mA which seems high to me. Any one have an idea as to what the current draw on the 5VST rail should be? I suspect there was damage to the main signal processing chip via a voltage surge on the HDMI input. (We lost one of the HDMI inputs on another TV in a different room and also an HDMI switch that was connected to that TV the same night). I did check the clock oscillator circuit with an oscilloscope and have a good clock when I power up the chip via the 5VST rail. I have not yet checked for clock and data activity on the EEPROM or FLASH chip to see if the main processor is trying to load the code, but will do so the next time I work on this.
    One oddity I noticed was after having the TV opened up on the bench and connecting and disconnecting AC power many times over several days, the back light never came on. After thinking about the menus popping up and thinking that the button control panel might be at fault, I unplugged the button panel and the back light popped on. It stayed on for a minute or two and then went back off. I never could get that to repeat and the TV is completely dead as before.
    I emailed Insignia trying to obtain a service manual but received the non-helpful response that they would not sell me a service manual as the information was proprietary, so no help there.
    So in summary, my questions are:
    1. Anybody know where I can get a service manual for this TV?
    2. Anybody know what the standby current on 5VST should be for a known good set?
    3. Anybody know what the main signal processor chip is and where I could find a replacement? (I have not yet removed the heat sink to look for markings).
    Thanks in advance for any help provided.
    Ronnie
  • nomoresonys
    • 12269
    • U.S.
    Re: Insignia NS-50LC240A13 questions
    First thing I would try is a firmware update/reapply.
    • asel51
      • Jan 2019
      • 5
      Since it appeared that the main TV signal processor IC was damaged, I found a replacement main board on EBay from Electroparts Warehouse. Before installing the replacement board, I applied power on 5VST and found that it pulled around 100mA, not the 650mA that the original (bad) board pulled. Also, there was no detectable temperature rise on the 5VST to 3.3V LM1117 regulator or on the main IC. I installed the replacement board into the TV and it worked well and the TV is functioning again. Afterwards, I again powered up the original bad board with 5V on the 5VST rail and noted the same 650mA current draw and noted that the board area under the main IC was getting warm. Therefore, it appears that the main IC had an internal failure. If I can figure out what the chip is and find one, I will try to replace it and see if that will fix the failed board.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8324
        that's where I'd be pointing too, since the main IC is probably a MSD chip. All you can do is either to replace the MSD IC or the whole main board.
        • patrax
          • Feb 2014
          • 33
          I would go with the failed MSD IC on the main too, even the slightest ripple in voltage is most likely going to toast it. I suggest replace the main they are problematic to put it lightly. Looking at the schematic for most Insignia sets there is little to no fault protection in any of them. The LED models also have the lowest quality LEDs Ive ever encountered too.
          • nomoresonys
            • 12269
            • U.S.
            Agree avoid Insignia tvs if possible, plus the picture quality is shit.
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
            • PlasMatt
              LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
              by PlasMatt
              I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
              09-20-2025, 06:50 PM
              HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
              This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-12-2024, 02:30 PM
              HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
              HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
              09-06-2024, 08:10 PM
