Element ELSW3917BF
  • GAStuntman
    • Dec 2017
    • 65
    Element ELSW3917BF
    I need help with this element tv. It has a flashing red light. I'm not getting any readings for the mainboard. I don't see a power supply board on the tv so I'm guessing it's apart of the mainboard. I have replaced the mainboard & it didn't fix the issue. Any suggestions?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Element ELSW3917BF
    What DC voltage do you have between the two legs of the large CapXon capacitor.
    Is there a hole in the component the red arrow points to?
    • GAStuntman
      • Dec 2017
      • 65
      Yes there is a hole but I’m not getting any voltage from the component
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Can you provide a closer photo of that component. Are you saying there is no dc voltage between the two legs of the large capacitor?
        • GAStuntman
          • Dec 2017
          • 65
          That’s correct. When I test the component I get 0. The weird thing is I’m not getting voltage from that component on either board the new one or the replacement board. Looks like I’m having the same issue with both boards.
          • GAStuntman
            • Dec 2017
            • 65
            I get 3.6 voltage on the component circled in red but no voltage on the one circled in yellow.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              So there's no DC voltage between the two legs of the large CapXon capacitor but you can measure 3.6V DC on one of the components on the circuit board. There are 3 pins to that component. Can you measure what is on each and what is the part number written on it.
              Do you have any other voltages which may be written on the circuit board eg 12V
              Edit
              Read through this thread which uses the same circuit board.
              https://www.badcaps.net/forum/showth...ight=st6308%2A
              • GAStuntman
                • Dec 2017
                • 65
                The capXon has 172 v and no burn holes in the component. Each leg on the component is showing mv on the outside legs & 0 voltages on the inside leg. I’m getting voltage on the hot side but it’s fluctuating from 10 volts to 12 volts back to 10 and so forth. It’s cycling power
                • GAStuntman
                  • Dec 2017
                  • 65
                  I think the board I received was a bad board. The replacement board is doing the same thing as the original bad board. Now, I’m wondering if I can use both boards to make one good board or should I just order another board.
                  • Mirenia
                    Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                    by Mirenia
                    I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                    I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                    In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                    The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                    03-30-2025, 06:47 AM
                  • orcic
                    MASTER TL240 and new mainboard LW36BKC01
                    by orcic
                    I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                    The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                    After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                    Now I have some doubts about how to connect the new mainboard to the old power supply.
                    First of...
                    05-12-2023, 08:10 AM
                  • flysky
                    Gigabyte H610M S2H V2 help to identify the element.
                    by flysky
                    There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
                    Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
                    01-23-2025, 07:21 PM
                  • Malva
                    Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                    by Malva
                    I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                    Mainboard model: EAX65684604
                    PCB marking: EBT62954607
                    SPI chip: Winbond W25X20CLNIG Problem description:
                    Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                    After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                    • I bought another
                    06-25-2025, 02:07 PM
                  • EasyGoing1
                    The best way to drive a heating element?
                    by EasyGoing1
                    I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                    What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                    This is the general setup that I have now.
                    This is what the...
                    01-25-2023, 11:29 AM
