LG 55EC930V OLED - 3 Second Power No Display
  • Dac12
    • Aug 2025
    • 31
    • Uk
    #101
    Originally posted by Dac12
    Earlier it was responding to the remote but I kept tampering with the microswitch and now its not responding. But everytime I press the microswitch the shading and the percentage of screen shaded changes.
    I should have entered the code via a normal remote. But i dont really want to give up on this yet. Is there anyway of getting it back to the lockdown stage? I just disconnected the tcon ribbons and it went back to lockdown.
    I've added two photos and the chip I assume below this ans the rubber is very hot to the touch, maybe a fault?
    Sorry just realised the photo was missing.
    • Dac12
      • Aug 2025
      • 31
      • Uk
      #102
      Originally posted by Diah
      unplug the EVSS 24V block from PSU side... and send In_Stop when TV go to STBY plug it out from wall for 10 minutes to discharge and put back EVSS socket then turn on
      you can also run PSU and T-CON driver bords and OLED as standalone state... it could show you the effect if the OLED defekt
      Thanks I did exactly as you said I unplugged the EVSS 24v and it went back into STBY. Sorry I'm a bit new to this, if I correctly understood the procedure. Turn the tv on , disconnect EVSS from psu side, keep pressing In_Stop until TV goes into STBY. Reconnect EVSS connector. Don't I then press the microswitches and try to input lg code as per other posts? (I've attached a photo of the display again, but I haven't done your procedure yet, the screens not cracked it just a shadow from furniture)
      • Diah
        • Feb 2013
        • 6568
        disconnect the EVSS, turn on the TV ( screen remain black ) ... send In_Stop -- followed with code via RC 0413 ... TV go to STBY.. leave it 10 minute to discharge ... EVSS socket back then Turn on-- do first install
        • Dac12
          • Aug 2025
          • 31
          • Uk
          #104
          Unfortunately no success , the relay keeps clicking every approx 2 to 3 seconds. After disconnecting evss as per photo and switching on the tv it just keeps clicking.
          • Diah
            • Feb 2013
            • 6568
            put back the EVSS, just disconnect the lower LVDS from MB side , check (screen will remain black )
            • Dac12
              • Aug 2025
              • 31
              • Uk
              #106
              Thanks tried that but just clicking every few seconds but the mb red led not lighting up. Either I'm missing a step or I've messed the sequence by messing around with the microswitches or the panel is beyond repair?
              • Diah
                • Feb 2013
                • 6568
                by disconnecting the lower LVDS we are here cuting the SOS signal from t-CON in case the panel have fault.... but yours look like now the MB .. or microswitches one of them keep in push position... you need to check
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4539
                  • Italy - Milan
                  #108
                  But i do not see a chip or rubber, only a screen...
                  • Dac12
                    • Aug 2025
                    • 31
                    • Uk
                    #109
                    Sorry fourth attempt at trying to upload the photo. Sometimes it get hot to the touch.
                    • Dac12
                      • Aug 2025
                      • 31
                      • Uk
                      #110
                      Will do thanks
                      • Dac12
                        • Aug 2025
                        • 31
                        • Uk
                        #111
                        I've tried to attach your post but struggling to attach it
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4539
                          • Italy - Milan
                          #112
                          It is not the first nor the 100th but more of the LG cpu that can be soldering ruined...
                          • Dac12
                            • Aug 2025
                            • 31
                            • Uk
                            #113
                            Do you mean the lg cpu may require soldering?
                            Thankfully i got the normal remote working again but only the on and off function. The lg service remote works as well but when i press in_stop followed by 0413 and ok nothing happens.
                            Some times the tv does makes a whooshing laughing sound. I've connected an old ps3 console but no display change. I've tried a wireless mouse but no display change.
                            I assume in_stop isnt working because the tv isn't going into standby. I've seen a video where pressing the menu button over 10 times is the same as in_stop and then they enter 9876 and then 0413 and again 0413.(?).
                            any suggestions would be appreciated? Thanks
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4539
                              • Italy - Milan
                              #114
                              I mean CPU can easily be the problem, stop
                              • Diah
                                • Feb 2013
                                • 6568
                                don't miss up with SoC soldering.. .. i wrote MB, not SoC... yours MiCOM firmware distributed because of playing with microswitch which had nothings to do.... try disconnect pin 6 of MICOM and try IN_STOP
                                • lotas
                                  • Jan 2016
                                  • 4862
                                  • Russia
                                  #116
                                  IN_STOP will not work, because the IR sensor of the remote control is connected to pin 6, i.e. the TV will not receive signals from the remote control.
                                  • Dac12
                                    • Aug 2025
                                    • 31
                                    • Uk
                                    #117
                                    Thank you where would we find this ic3000 ? Would it be on the MB? Secondly if pin 6 is disconnected will the seevice remote work? We checked mainboard but we can't see this ic3000?
                                    Found it , I think please see attached photos- but how would this be disconnected? Sorry I'm new to this
                                    • Dac12
                                      • Aug 2025
                                      • 31
                                      • Uk
                                      #118
                                      We've found pin 6 but how do we disconnect this? Which one route no 6?
                                      • Dac12
                                        • Aug 2025
                                        • 31
                                        • Uk
                                        #119
                                        QUOTE=lotas;n3707055]IN_STOP will not work, because the IR sensor of the remote control is connected to pin 6, i.e. the TV will not receive signals from the remote control.[/QUOTE]
                                        Ignore this is wrong chip
                                        • lotas
                                          • Jan 2016
                                          • 4862
                                          • Russia
                                          #120
                                          Here is micom ic3000, but the remote control will not work if you cut the track to the 6 pin
                                          • learnmore
                                            Lg oled 55ec930v automatically turns off after 1-2 seconds
                                            by learnmore
                                            Hi Community,
                                            I've got the above model that activates the relay (clicks) and powers on the LG logo power light on when turned on. It then almost immediately turns off. I not noticed any image on the screen or heard any sound during this brief period.
                                            Checks show:
                                            3.5v on SMPS on (in off state, no other voltages present incl pwr on)
                                            On pressing power button > the 3.5 pwn on voltage, 12v and 24v lines appear on the SMPS connnector between the main the SMPS but then all drop the zero in 1-2 seconds
                                            Disconnecting 24 to TCON connector and powering on shows...
                                            05-08-2024, 02:42 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:40 AM
