Samsung UN60J620DAFXZA slow motion.
  • capwizard
    • Jun 2016
    • 1991
    Samsung UN60J620DAFXZA tv screen has pic2 slow motion. is this Tcon or sceen poblem?
    Any help would be appreciated.
  • capwizard
    • Jun 2016
    • 1991
    Re: Samsung UN60J620DAFXZA slow motion.
    give it a short and Keeping my fingers crossed so I ordered T con board.
    I have found traces of German cockroaches inside and a small still alive German cockroach.
    My question is will German cockroaches detory the screen COF taps? This TV is A okay without a serious bugs infection.
      • 12206
      • U.S.
      Looks to be a panel problem, "cut tape" method works for some, lots of info here and youtube on method.
      • budwich
        • Jul 2015
        • 3097
        the horizontal line would appear to indicate a problem of the panel as opposed to the tcon. Your "friends" may have "spit" on some of the areas along the panel edge or on the bottom edge boards. Look for any contamination there in... you might get lucky and find some areas that just need a bit of cleaning. As suggested, the "tape cutoff" method of putting a small put of tape on one of the tcon to panel connectors to block some of the signal pins may revive the set.
        • capwizard
          • Jun 2016
          • 1991
          Thank you, budwich, Don't you remember we had done it together, castrated a Sharp 70" TV?
          Sharp Aquos LC-70LE650U display is slow and discolored
          https://www.badcaps.net/forum/showthread.php?t=59932
          i did the same thing, castrated a Samsung 55 tv that was a big catastrophe, it did not work.
          I still don't know how it works. What is the working principle for all those mickey mouse works ? Something must be wrong. I hope somebody can help me with this.
          • CapLeaker
            Leaking Member
            • 8218
            All the slow motion stuff on the screen I've had it was always the tab bonds on the panel.
            • capwizard
              • Jun 2016
              • 1991
              Thank you I already prepared to jumper wire VGON, VDDG or cut CKV1, CKVB1.
              For COF tabs I'm going to homemake a portable cof bonding machine.
                • 12206
                • U.S.
                Strip it down n play with the tabs, check for changes in display.
                • capwizard
                  • Jun 2016
                  • 1991
                  my friend I did that already
                  • budwich
                    • Jul 2015
                    • 3097
                    Perhaps you misunderstand. The suggestion of the "tape cutoff" method is not a "catastrophe" event as it does nothing to the set that can't be reverse... one just needs to take the tape away to start again. IF you are referring to the "tab removal", then that's a different technique and is not reversible. The "tab removal" method has not been suggested for this problem.
                    • capwizard
                      • Jun 2016
                      • 1991
                      Thank you. I saw that ebook has very detailed explanation . The better way to do it and more precision and reversible.
                      • budwich
                        • Jul 2015
                        • 3097
                        The ebook explanation appears to be good but not without hazard as it is dependent on "repair talent" which an individual may not have mastered. I believe the "tape cutoff" method is somewhat less risky. Either way, the ultimate goal is to get a working set. Good luck / success in your operation. Personally, I would try the less intrusive tape cutoff method first to see if one can achieve a noticeable result. If not, then proceed to the "track cutting" method as at that point, there would be little else one could do to save the set.
                        • capwizard
                          • Jun 2016
                          • 1991
                          Thank you, I fully understand..... the conclusion as follow:
                          screen repairs vs male method of contraception
                          "tape cutoff" method is same as use condom
                          "track cutting" method is same as ligation
                          "tabs cuts off" method is same as castration
                          • CapLeaker
                            Leaking Member
                            • 8218
                            lol
                            • capwizard
                              • Jun 2016
                              • 1991
                              Only this could express my feelings right now.
                              T con board came today and it works like a champ and I keep on saying sorry to Germany cockroaches which left marks all over the COF tabs. Picture 2
                              Thanks for everybody's help
                                • 12206
                                • U.S.
                                Indeed, that's why it's not always a good idea to jump to a bad panel snap diagnoses, in some cases it's just very hard to determine if it's tcon or panel, glad it was an easy fix.
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  i mistype German cockroach to Germany cockroaches.
                                  For example, although it is widely known as the "German cockroach" in English-speaking countries, in Germany in turn, it is known as the Russian roach. ......wiki
                                    • 12206
                                    • U.S.
                                    LOL, looks like nobody wants to admit to owning those roaches.
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:20 PM
