Jvc lt32c351 EPROM dump please
  • D1964
    • Apr 2015
    • 6
    Does anyone have the EPROM dump u6 for this set,
    Panel and main board are
    ST3151A05-8 BOARD MS308C1-ZC01-01
    Thanks David
  • mirovdbg
    • Jul 2018
    • BULGARIA
    Re: Jvc lt32c351 EPROM dump please
    I need that too, please
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
