Panasonic TX-P50U20B - hours logged before failure
  • andyb1712
    • Oct 2018
    • 41
    • United Kingdom
    I recently acquired and repaired a TX-P50U20B and checked the hours usage in the service menu.
    For an 8 year old tv it had clocked up an impressive 37,000 hours plus - that's over 12 hours a day, every day before it failed.
    That despite the fact it's the base 1080p model with no cooling fans and no heat sinks on the Y buffers and the notorious TNPA5105 SC, which was the failed part.
    Anyone seen higher hours before failure?
  • kd9
    Panasonic working hours bios location
    by kd9
    Hello, can someone tell me where the operating hours are located in the bios (string)? I have a client with a cf-20 who wants to reset them but I don't know where that information is found in the bios I we checked 2 versions of the bios but there are multiple large arrears that are changed . Thank you.
    โ€‹...
    04-03-2025, 09:47 PM
  • Andre Gilbert
    by Andre Gilbert
    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here๐Ÿค”?
    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting ๐Ÿ˜‚.
    11-20-2024, 08:52 PM
  • AquaMan Ua
    by AquaMan Ua
    05-17-2025, 09:40 AM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    The TV does not turn on, the standby indicator is on. All voltages are present.
    Emms is dead. Not readable, not detected.
    Replaced emmc.
    But with another dump there is no launch
    Terminal log
    UART
    AC_ON
    RPMB key is not yet programmed
    HASH1_VERSION=0x00000000 64bit
    E-B
    FDE enabled
    layout pattern onebin by SAR7,0...
    06-01-2025, 02:11 AM
  • JohnML1975
    LG 49UK7550PTA - after couple of hours screen starts to blink
    by JohnML1975
    Hello Forum team
    Have this TV; searched for the model and could not anything so thought I would share in here
    Had an issue, some years ago, and looks like some placed sticky tape over some of the lines on the FFC cables between the T con and the mainboard
    Anyway, the owner, who gave me the TV, says it starts to blink after a few hours
    So I removed the covers, and could not see anything visibly
    Removed the power supply and thought some of the solder joints, on the hot side, were not the best. I thought some looked like they were cracked.
    07-25-2025, 10:48 PM
