Lg60PK750
  • rccrasher65
    • Mar 2014
    • 625
    Lg60PK750
    I have a LG60PK750 plasma tv. Tv works just fine for about 20min then shuts itself off. Tv will click and turn itself off, and will not respond at all with remote or buttons on set. All voltages are correct while tv is working. seems to me its heat related, any suggestions on what to check would be appreciated. Going to check for bad solder joints.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Lg60PK750
    Disconnect the connector going to the Y-sus Bd. Connect two 120Vac household bulbs in SERIES and connect them across Vs and GND on the connector. Apply the ac, the light bulbs should come on. Wait for the 20min time and see if it the bulbs go out or if the all other voltages Va, 12V, 17V. M5V, etc drop out on the PSU.
    • rccrasher65
      • Mar 2014
      • 625
      Re: Lg60PK750
      Will do, thank you for your response.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Re: Lg60PK750
        Any luck??
        • rccrasher65
          • Mar 2014
          • 625
          Re: Lg60PK750
          No haven't done anything as of yet because of Holiday. I will as soon as some time frees up. thanks will let you know.
          • rccrasher65
            • Mar 2014
            • 625
            Re: Lg60PK750
            No haven't done anything as of yet because of Holiday. I will as soon as some time frees up. thanks will let you know.I had a Samsung set do this a few years back and it ended up a cold solder joint. hope for same!
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Re: Lg60PK750
              Yes, do look for cold solder joints
              • rccrasher65
                • Mar 2014
                • 625
                Re: Lg60PK750
                Well found a few questionable joints, hope that takes care of problem, will test after the holidays. thanks for all your help and have a very Merry Christmas!
                • Capacitorial
                  Powersupply has all the voltages - Monitor still no power
                  by Capacitorial
                  Hello guys,
                  I have a Philips 240B7QPJEB. The monitor seems completely dead.
                  I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                  On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                  The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                  The weird thing is, that the Power LED is powered over the TCON board.
                  On The TCON...
                  12-28-2024, 02:12 PM
                • jesi
                  macbook pro a1707 dead
                  by jesi
                  hi all techs
                  require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
                  adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
                  update:
                  when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
                  08-24-2025, 04:34 AM
                • jesi
                  MacBook Pro 820-00281-A A1707 macbook
                  by jesi
                  hi all techs
                  update:
                  08-23-2025, 02:35 PM
                • gjgib
                  Help reading schematic voltages input/output
                  by gjgib
                  Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                  I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                  I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                  I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                  05-06-2024, 08:11 PM
                • RossMoodley1967
                  HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                  by RossMoodley1967
                  Hello
                  Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                  Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                  03-01-2024, 06:07 AM
