Hitachi 55hdx62
  • mrosenberg42
    • Aug 2008
    • 27
    Hitachi 55hdx62
    I have a Hitachi 55hdx62 that will not power up. The power supply shuts down in about 1/2 a second after pushing the power button. I have gone through almost all components on the power supply the x sus and ysus boards. Their are only two that I am suscpicious of. One smd aluminum electrolytic cap and a much larger cap. I cannot find any data sheets on either capacitor. The markings on the small smd cap are 5J 22 JLD. I also tried to find a data sheet for the other larger capacitor. But when I do a google search I get nothing from the part number on the cap. The large capacitor measures an ESR of 32 ohms and the small looks to be 22uf capacitor has an ESR of 3.2ohms. If anybody could help me identify either capacitor that would be really appreciated. I attached the pics of the caps I'm looking for. Thanks.
  • Wizard
    • Mar 2008
    • 2296
    Re: Hitachi 55hdx62
    That is poly (not polymer) cap drop. 43nF in size 1.25kV That's certainly found in the horizontal deflection circuit. Not dependent on ESR. It is special application and usually it doesn't fail very often, if it does, it burst open or burned.
    The SMD cap is 22uF as you thought. Voltage is denoted as a letter, that one is 6.3V by this J.
    Keep looking, this is not quite the issues.
    Cheers, Wizard
    • mrosenberg42
      • Aug 2008
      • 27
      Re: Hitachi 55hdx62
      Thanks Wizard. The poly cap is actually in the early stage of the power supply. Would the power supply be fairly sensitive to esr? Also how did you know it was a 43nF cap? Is their a database to find these values? the smd cap is located on the main digital board. There is another one of the same caps that measures an esr of .42ohms while the suspect one reads 3.2ohms. Thanks for the info.
      • Krankshaft
        • Jan 2007
        • 2328
        Re: Hitachi 55hdx62
        If the PSU is shutting down quickly and there are no cap problems then most likely it's a protection circuit kicking in.
        Probably due to a faulty component shorted out (drawing too much current) on one of the rails.
        A schematic of the power supply section would be helpful. Since it's a Hitachi and not a Chinamart brand this shouldn't be hard to obtain.
        • PlainBill
          • Feb 2009
          • 7034
          Re: Hitachi 55hdx62
          Searching for 'capacitor labeling' or 'capacitor codes' will bring up may pages of information. One example:
          PlainBill
          • MORETTIGIAN
            Capacitor detached from PCB – RTX 2070 Super Founders Edition
            by MORETTIGIAN
            Title:
            Description:
            During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
            I did not notice it detaching, so I am unsure of its original location on the PCB.
            Procedure performed:
            - Removed backplate
            - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
            - Reapplied thermal compound
            - Reassembled card
            Observed behavior after reassembly:
            - GPU powers on and operates normally under...
            09-18-2025, 12:14 PM
          • cap__
            Can I replace 15uf capacitor with 22uf?
            by cap__
            "If I wanted to replace an old 15uF/400V capacitor with a new one,
            I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
            11-29-2023, 11:16 AM
          • Prolog
            RTX 3080 FE Identifying capacitor
            by Prolog
            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
            I hope these photos make it clear which component I am referring to:
            (yes, the soldering is a bit botched from removing the blown one, I know)
            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
            12-01-2024, 08:27 PM
          • Agent24
            Dick Smith Q-1760 linear power supply filter capacitor question
            by Agent24
            I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
            It has at least one problem.
            The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
            I have already ordered a replacement potentiometer, so that's not an issue.
            Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
            All are CapXon...
            10-21-2025, 05:39 PM
          • chth96
            If I replace with inferior capacitor, Is it No harm to other IC components at all?
            by chth96
            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
            I know that these capacitor will not last as long as nichicon capacitor...
            12-22-2023, 04:34 AM
