SAMSUNG PS50C7705YS loss power
  • Munem2x
    • Dec 2018
    • 7
    • Serbia
    I have Tv with some strange problem
    Samsung
    Model:PS50C7705YS
    Model Code:PS50C7705YSXXE
    Problem:When everything is connected power drop fast(from 211v to 0v) with quick flash on screen.When i disconnect ribbon cable(YSUS) from T-CON,Vs stay normal (211v).
    Any suggestion?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: SAMSUNG PS50C7705YS loss power
    Disconnect the connector with the Vs voltage going to the Y-sus and Z-sus Bds. Connect a 230V or two 120V household bulb/s across Vs and GND. Apply the ac. If the PSU is good the bulb/s will light up bright and remain ON. Problem is on another board. If this does not happen PSU is bad.
    • Munem2x
      • Dec 2018
      • 7
      • Serbia
      Bulb works normally....
      Any other suggestion?
      • Munem2x
        • Dec 2018
        • 7
        • Serbia
        Look like T-Con board can be problem.... When i disconnect cable from t-con board TV have normal voltages
        • Munem2x
          • Dec 2018
          • 7
          • Serbia
          after few test and youtube videos,problem is Y buffer board,shorted chip
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • mrtek
            Samsung UN43NU6950FXZA No power
            by mrtek
            Hi
            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
            Main fuse = OK
            Back light LED = OK. Power them with aux power source
            LED output = OK 156V
            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
            07-20-2025, 08:06 PM
          • hill01
            Samsung UE75MU7009TXZG Endless Power Cycle
            by hill01
            Hi everyone and thanks in advance for any help I might get here
            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
            Since a few days, the TV won't turn...
            11-17-2021, 02:52 PM
