Torque Specs for RG-6 connectors.
+ More Options
Posts
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Hello!
    Could someone recommend the correct torque value for RG-6 connectors? I sent an email to PPC, a Belden Company, where we purchased a bunch of EX6XLPLUS RG-6 connectors for quad-shield coax. They sell some torque wrenches and their datasheet recommends one of three torque wrenches, where the torque value is either 20 in./lbs or 30 in./lbs.
    However, researching the topic at hand, I came across an article that says 20 in./lbs might be too much for devices like cable modems, set top boxes, etc. and they recommend 10 in./lbs for such devices.
    So, should we be using two different torque values, one for settop boxes, cable modems, etc, and then a second value for our splitter?
    And what are the torque value that should be used? Thanks!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • R_J
    • Jun 2012
    • 9535
    Re: Torque Specs for RG-6 connectors.
    Most of the rf jacks on consumer equipment these days can't handle anything more than hand tightning, no wrenchs, you will twist the connector off.
    • petehall347
      • Jan 2015
      • 4426
      nip it up
      • Spork Schivago
        • Mar 2012
        • 4734
        That's what I needed to know. I've contacted the company who makes the RG-6 ends I'm using (PPC, a Belden Company) and they say 30 in/lbs is what I should be using.
        For the consumer equipment, I will hand tighten and then a little bit more. For the more expensive business type equipment, I will try to torque them to 30 in/lbs and just see how it works. If it feels like it's going to break or way to tight, I just won't apply the full 30 in./lbs.
        Thanks!
        • R_J
          • Jun 2012
          • 9535
          On satellite lnb's and quality splitters etc. I just hand tighten then just snug them up with a wrench so they can't be remove with youur fingers, there is no need to over tighten them.
          • Spork Schivago
            • Mar 2012
            • 4734
            nip it up
            What do you mean nip it up?
            • Spork Schivago
              • Mar 2012
              • 4734
              Another quick question. I have quad shield RG6. I strip it 1/4" x 1/4", which exposes the outer braid. I fold that back. Do you guys remove the second layer of foil and fold the third layer of braid back as well or do you guys leave that 2nd layer (the first outer layer of foil) on the dielectric?
              I noticed even though these ends are made for quad shielding, pushing them on without folding back the braid, removing the foil, folding back the 3rd layer (braid), it's almost impossible to push the RG6 connector onto the cable.
              I'm just hoping I don't affect the shielding qualities of the cable by doing this. I just don't see how else it's possible though.
              • CapLeaker
                Crimping CAT7 connectors high failure rates
                by CapLeaker
                I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
                Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
                11-09-2024, 04:11 PM
              • Eniaro
                Are USB C connectors standard
                by Eniaro
                I have a number of laptops with damaged USB-C connectors.
                I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
                I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
                I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh).
                07-24-2023, 03:07 PM
              • corrize
                Desoldering - soldering BGA chip close plastic mini fpc connectors ?
                by corrize
                Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
                There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
                I have :
                - hot air, and a
                ll stuff around
                - true kapton tape
                - 140 and 180 degree soldering paste
                - bismuth
                - little hot plate 250 degree max
                - the new BGA chip with probably
                05-20-2025, 01:26 AM
              • corrize
                How to clean fpc connectors oxydated ?
                by corrize
                Hello, do you know if it is possible to clean oxydated fpc connectors until it back brilliant please ?
                I know the best is to replace, but sometime micro fpc are very little oxydated and very hard (or unable) to find as new. So, there is may be a chemical product for that ?
                I use vinegar for rust on metal screw or little metal pieces and I finish with WD-40 for protect, else the rust can come back. That works pretty good.
                I not yet tryed on connector. Do you have a good method please ?
                10-20-2024, 07:29 AM
              • fuzzy4
                Identify Cable connectors
                by fuzzy4
                Can someone identify the connectors on this cable and what it's used for?
                I recognise the BNC and what looks like power.
                The middle connector, is a BNC adaptor.
                Thanks...
                09-08-2024, 02:37 AM
