Samsung UA 46D8000 Vertical coloured lights on one side
  • freemurti
    • Nov 2018
    Hi guys,
    Will appreciate if anyone can help.
    My TV is showing muticoloured very narrow vertical lines on one side (left) & that is very slowly progressing over time. It starts immediately after switching on & remains on all inputs.
    Do you feel its T-con issue or its the Panel which is doomed. Any easy way out?
    Thanks a lot for helping out.
  • zomi
    • Nov 2011
    • 505
    Re: Samsung UA 46D8000 Vertical coloured lights on one side
    Looks like a bad panel
      • 12206
      • U.S.
      Looks like the usual culprit, left tab bond, could strip it down and applying a little pressure on tab bond, see if it clears up, if so a shim might work.
        • 12206
        • U.S.
        One video there, can find better ones with some searching. https://www.youtube.com/watch?v=8l5ORKjQF5U
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          As nomoresonys suggests, I would agree with that and or bad panel.
            09-07-2024, 05:50 AM
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
          • kotel studios
            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
            by kotel studios
            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
            08-06-2025, 02:07 AM
          • polaro
            Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
            by polaro
            Greetings,
            I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
            08-27-2022, 08:46 AM
            09-06-2024, 11:40 PM
