Hello, I have samsung plasma 43h4100 AR, no sound no picture when I power the tv, but I only hear strange sound coming from the screen, all voltage from the zsus vs 206 VA 58 ok . any help
Samsung plasma 43h4100 AR making Strange sound
Re: Samsung plasma 43h4100 AR making Strange sound
Would you be able to describe the sound or record it?
Does the screen have any cracks, damage etc?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
If it seems the sound is coming from the screen itself, a low growling type sound that seems to change with the video (if a source is connected) I agree with Tom, either a cracked screen or delaminated panel (lost inert gas)Comment
not at all, no damage that I can see, all I know when I put my ears around the screen I hear the sound, I also noticed as the tv is coming up the sound change then after it remains stable, I most be frank, I did not connect any input to know if it has sound or not.Comment
Post clear photos of all the circuit boards in the TV (from your TV, not pictures from the internet), and an overall picture of the whole TV with the back panel removed.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by mrtekHi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...6 Photos
by mar1inHi everyone,
I've got this Samsung here that would be stuck in a boot loop.
After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
Thanks in advance -
by ChrissygizmoHi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
Ive eventually managed to get it on and working but it's very temperamental...
The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...05-26-2024, 12:05 AM -
by bohabohaHi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
anyhow i couldn't t read anything else
the backlight is on strong and the screen does not get dark or very dark but no pictures
the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
... - Loading...
