Video not working on LG 49UF6800 (menus and sound works)
  • cocacola
    • Mar 2017
    • 12
    Hi, I have an LG 49UF6800 that's having some issues. All of the menu screens work fine, but none of the video inputs are working. I've tried the AV input, as well as all 3 HDMI ports, as well as the built in apps such as Netflix. I can hear sound on all of them, but there's no video, it's just snow/lines (attached photos showing this). I can see the Netflix app and all the movies/shows, but when I click one I just hear the audio and get the same snow/lines, in the attached photo you can see if I skip forward in a movie it even shows the thumbnails at the bottom, but still no video.
    So far I've taken the back off and taken out the main board to have a quick look at it, nothing obvious stood out to me as an issue but it was just a quick initial scan and I just wanted to reseat the cables to make sure they were connected properly as well. I've also did the most recent software update hoping that might help but it did not.
    Another note, I'm fairly savvy in electronic repairs and have tools such as a multi-meter, soldering station, etc. I just haven't worked with many TV's before.
    Would anyone have any ideas as to what this might be/how I could repair it? Thanks in advance, any help is greatly appreciated!
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: Video not working on LG 49UF6800 (menus and sound works)
    interesting .
    take some good pics of the whole rear side and various boards .
    • cocacola
      • Mar 2017
      • 12
      interesting .
      Sure thing, here's a handful, if there's anywhere I need to get a bit closer just let me know. Thanks!
      • neilc6
        • Nov 2015
        • 1550
        Looks like that model has BGA issues on the main board.
        https://www.ebay.com/itm/Mail-in-Rep...KXSI:rk:1:pf:0
        • cocacola
          • Mar 2017
          • 12
          Originally posted by neilc6
          Looks like that model has BGA issues.
          Thanks for the reply. Yeah from reading about this model a bit more in things like Amazon reviews I've seen a few people mention this same issue, from the ones I've read it does seem like the issue is with the main board. Unfortunately that eBay listening doesn't offer shipping to Canada, although maybe I could message them and ask, it's still a bit out of my budget. The cheapest new one I could find seems to be over $300 CAD as well unfortunately..
          I found a video of someone showing the same issue with a similar TV, figured it might be valuable to share here as well: https://www.youtube.com/watch?v=gdWqF5G17SE
          I'm guessing the chip which needs to be replaced/reworked is the one in the middle under the black heatsink?
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            looks most likely suspect to me . can you not file not fit for purpose claim if its worth lots of money when working ?
            • cocacola
              • Mar 2017
              • 12
              I'm not too sure what you mean, could you go into a bit more detail on what that is? Thanks!
              • Diah
                • Feb 2013
                • 6560
                its much glitch at firmware, time to send command IN STOP via IR to clean any bad cache. and reset the eeprom to factory condition
                if with IN STOP no better, then just reheat the large IC CPU
                • cocacola
                  • Mar 2017
                  • 12
                  Could you give me some more details on how I can do this? I've done some searching on IN STOP but not finding much info on this so I'm not sure where to begin.. Thanks!
                  Also, is this the same as resetting to factory settings? I did that through the settings menu already but unfortunately that did not help.
                  • Diah
                    • Feb 2013
                    • 6560
                    if you have underhand Android mobile with IR blaster like Galaxy S5 , at the Google market apk called Smart IR Remote, when you set it as remote to LG TV you will have click as IN STOP, the apk i posted over this forum too.
                    IN STOP is Hard reset more effective than factory reseet under the menu UI
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      lg apk
                      • cocacola
                        • Mar 2017
                        • 12
                        Thanks for the reply. After some more research earlier I was able to figure it out and I did "IN STOP" and it reset the TV but unfortunately that did not solve my problem.
                        I just reset the eeprom as well but still unfortunately it's not working.
                        I may heat the chip as a last ditch effort to get this one going unless there are any other ideas. If that's the case do you figure the correct chip would be the one under the black heatsink in the middle of the board? I would assume that would be the correct one but I also see a large silver heatsink in the corner so thought maybe that could be it as well..
                        • cocacola
                          • Mar 2017
                          • 12
                          lg apk
                          • neilc6
                            • Nov 2015
                            • 1550
                            Reheating the chip may work temporarily but reballing is the proper repair. The lead free solder balls become intermittent. I've baked both a PS3 and laptop which both worked for a few months until the problem returned.
                            • Diah
                              • Feb 2013
                              • 6560
                              yes of sure reballing the chip the best way,, but thought this level not for home user,,
                              yes the one under the black heat sink, but try to cover with type the parts down side the chip as they may get loss by heat.
                              • ex250
                                Kenwood SW-505D no sound issue and pops from time to time when it works
                                by ex250
                                Hello mates,
                                I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                                It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                                12-29-2024, 03:27 PM
                              • JRade
                                Audio video receiver KENWood KR-V990D,no sound
                                by JRade
                                When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                                The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                                I replaced the capacitor C303/0.047F, nothing changes.
                                I'm asking for help, what should I do next?
                                Thanks in advance!...
                                08-05-2025, 10:23 PM
                                HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                09-12-2024, 02:00 PM
                              • ChaosLegionnaire
                                by ChaosLegionnaire
                                09-13-2022, 09:02 AM
                              • GraphicMan
                                Niky 1000 UPS making strange sparking noises (video)
                                by GraphicMan
                                anyone can explain what and why is this sound "ezz ez ez zzz" clearly starting from 0:34, the ups is niky 1000, i am using 7s6p good lithium 18650 cells pack, that sound only appear when i load any pc or lcd or crt, but never ever when using even much higher load 200w tungsten bulbs, althogh the sound, it never shut down nor give a warning and the pc or lcd or crt works completely normal at all times, in the video u can notice that the bx100 (voltmeter) is restarting with the sound, also the bulb flickers with the sound, i have checked only the largest cap on board (which is not that...
                                02-27-2024, 08:09 PM
