Sammy Plasma PN60F5500AF Firmware Swap
  • Michale32086
    • Nov 2011
    • 1453
    I have a PN60F5500AF that I have been trying to resurrect for the last couple months..
    Came across another board, identical to the PN60 Main, but still won't boot up the TV..
    Thinking of doing a firmware transplant.
    Is it a safe assumption that the WINBOND chip is the firmware chip???
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • gurj1979
    Ubiquiti firmware help. US-8-150W POE
    by gurj1979
    Hi guys.
    I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
    Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
    So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
    Got New chip and writes good.
    THE PROBLEM...
    It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
    Does anyone have a Good Firmware I can have?...
    07-22-2024, 05:13 PM
  • Slapito
    Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
    by Slapito
    I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
    Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
    I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
    I already downloaded the BIOS update file from msi official...
    10-09-2025, 02:00 AM
  • wattage
    AOC AG493UCX 49-inch monitor - Firmware request
    by wattage
    Hello Badcaps Community,
    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
    07-13-2025, 04:41 PM
