TV Samsung LN40C630K1F Won't Turn on
  • Tech06
    • Oct 2018
    • 9
    Need help with this TV. I am wondering if anyone has seen this problem before. I have the above listed TV. Will not turn on. Here is what I have tried.
    • Check Power supply voltages(13V is at ~ 12.8, 5v is at ~ 5.2)
    • Unplug main board (TV back light comes on)
    • Replace main board (still has the same symptoms)
    • Unplugged Tcon (still has the same symptoms)
    I am out of ideas here. When I plug the power in the standby light flashes 6 times. Nothing will turn on the set. I tried issuing the reset command via the remote. (standby light flashes when I press the remote buttons.) I have checked the other posts here and the symptoms don't fit. Attached are pictures of the new main board (green), old main board (blue), and power supply. Any advice is appreciated.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: TV Samsung LN40C630K1F Won't Turn on
    Your replacement mainboard is bad also. Return it and find another.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Your replacement board may not be bad but it definitely is the wrong item. The BN94 and BN41 Nos. are different on each board.
      • Tech06
        • Oct 2018
        • 9
        This was the right answer. Purchasing another Mainboard fixed the issue.
        • Tech06
          • Oct 2018
          • 9
          I purchased that one from the part number compatibility list that ShopJimmy had on their website. I would hope that on the newer boards Samsung would have worked out the bugs. When that didn't work, I purchased another mainboard that had the same part number but, was a newer revision.
          • PNI E.
            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
            by PNI E.
            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
            03-17-2025, 04:23 AM
            09-07-2024, 05:50 AM
          • Asraf Atb
            by Asraf Atb
            01-27-2025, 05:02 PM
          • Yanleb
            Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
            by Yanleb
            Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
            If they are not compatible why did Samsung give them the same part number to begin with?
            08-04-2025, 11:35 PM
          • elpatxi_bcn
            Samsung HG75EJ690UB Hotel TV, change main?
            by elpatxi_bcn
            Hello!
            I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
            Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
            The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
            05-19-2023, 03:21 AM
