JVC LT48N530A no image or sound power supply OK
  • dkneyle
    • Dec 2013
    • 445
    This is a Chinese clone or re-badge despite the JVC name.
    No image or sound. Nothing visible with the flashlight test. Tried accessing HDMI ports and playing a movie with no signs of audio output. Voltages on power supply seem to come up OK. The LED tell-tale on the front of the TV reacts to remote button control and goes from red to green in an expected manner.
    The LED backlight voltage gives a clue. At initial power-on it is sitting at about 35VDC. Then it briefly goes up to about 150VDC (about what I'd expect) before quickly cascading back down to ~35VDC.
    So, do you reckon I have failed LED string in the panel? If so, why can't I see an image with the flashlight test or get some sort of audio output via the HDMI port?
    There is secondhand mainboard available for sale but I'm reluctant to invest in that if I actually have a defective panel.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: JVC LT48N530A no image or sound power supply OK
    That sounds like a bad/open backlight string/s. Don't worry about not seeing anything with the flashlight test. Try looking when the menu is up. Sometimes it escapes us to see the flashlight test work.
    • dkneyle
      • Dec 2013
      • 445
      Any other votes confirming it's likely to be a failed LED string in the panel?
      • R_J
        • Jun 2012
        • 9623
        At the time the voltage went to 150vdc you would see the backlight if it was working, so very likely open led.
        • dkneyle
          • Dec 2013
          • 445
          Yes RJ, not even a flash from the LEDs. I did tell the seller that it was my suspicion and therefore she needed to accept there was little value in the set other than a few spare parts. Thanks all. Time to strip it down I think.
          • R_J
            • Jun 2012
            • 9623
            Check for a bad led, It might only need one replaced, might be an easy repair
            • dkneyle
              • Dec 2013
              • 445
              Just to close off the thread, I stripped it down, and checked the LED strips. 3 failed LEDs in total. So it was a panel fault.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                03-31-2024, 02:12 PM
              • stylishconsultant
                un60j620dafxza - Samsung No Display Problem
                by stylishconsultant
                Hi All,
                Need help.
                I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                09-04-2024, 03:26 AM
              • Rozp
                70LE660U dark cloud or black screen with sound.
                by Rozp
                Hello Everyone,
                This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                08-29-2023, 05:25 PM
              • Kartowl
                philips 47pfl6158k/12 image faded away, sound still coming from TV
                by Kartowl
                Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                04-23-2024, 12:57 AM
