Zener T3D98 data required
  • spdy
    • May 2018
    • 26
    • india
    I am trying to repair a Panasonic plasma 42 inch TV TH-P42C10D. one of the suspicious components is a Zener T3D98 which is showing infinite resistance on both sides using a diode check with a multimeter.
    I cannot find any data on this. I presume this is a high voltage 100, 150 or 200 volts zener in the power supply after the bridge rectifier and parallel to the transformer input.
    How can I get data on this and can it be checked with a DMM?
    Thanks.
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Zener T3D98 data required
    Very unlikely a zener or diode will go open
    Check again on diode setting on your multimeter
    • spdy
      • May 2018
      • 26
      • india
      Thanks. I have desoldered and checked it is open on both sides. I want to know if they have higher threshold voltage and therefore it does not show on the dmm I am using.
      I would also like to know what should be the voltage of a zener being used accross the bridge rectifier and trasnsformer of the smps?
      • R_J
        • Jun 2012
        • 9623
        That T3D98 has two diodes connected common anode, one is a zener one is a regular diode. It will measure open circuit
          Originally posted by r_j
          that t3d98 has two diodes connected common anode, one is a zener one is a regular diode. It will measure open circuit
          +1
          • petehall347
            • Jan 2015
            • 4448
            example .....
              The questions are:
              1) What is not working?
              2) What power supply section that this snubber diode is located in?
              3) Pictures of what we are dealing with?
              • spdy
                • May 2018
                • 26
                • india
                Thanks, that is why it is showing open on the dmm diode check. I will have to look at the power supply section of this tv again.
                • unimatrix93
                  TV backlight zener diode
                  by unimatrix93
                  Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                  So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                  Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                  The led strips has 9 6V leds.
                  02-10-2025, 12:13 PM
                  NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                  I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                  I bought this from an eBay seller but unfortunately they only had one
                  I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                  I bought three of from them to also make battery packs with this output power limit in mind
                  I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                  04-23-2025, 05:50 AM
                • nev1001
                  What zener diode might fix the sound on Maestro Mayhem gaming chair?
                  by nev1001
                  Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                  The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                  It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                  I think an issue could be a zener diode (or capacitor) which has shorted out.
                  The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                  04-17-2025, 05:09 PM
                • Vincenzo2
                  Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                  by Vincenzo2
                  My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                  Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                  I put some pictures here to show that it is labeled "M7"....
                  09-07-2023, 07:43 PM
                • bastien
                  OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
                  by bastien
                  It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
                  This is the new database for FlexBV
                  it's optimized to work with it
                  by using board ID has Default name, give us the opportunity,
                  to use other diode board data with sibling board or family board
                  I Merged the whole data (optimal)
                  A2991 A2992 M3 -> -> 2 Entries diode data M1
                  A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
                  A2442 A2485 A2779...
                  03-18-2025, 08:03 AM
