DVD player (JVC XV-F80) repair or replacement part needed
  • ceramic
    • Feb 2009
    • 11
    I'm working on this DVD player (JVC XV-F80) that was not working due to a DVD inserted incorrectly. When I opened it up the DVD was completely shattered with pieces everywhere. I managed to clean it out and everything was working but it wasn't able to play DVDs very well; it will slow down and pause sometimes. As at now, the DVDs wont play at all - I get a "No Disc" error when I insert a DVD. I tried several known good DVDs, same result. It works perfectly with audio CDs.
    My guess is the pick-up lens (part # LEA10024-01) is bad and need to be replaced. However I couldn't find any online. Any help at all will do. Thanks in advance.
  • PlainBill
    • Feb 2009
    • 7034
    Re: DVD player (JVC XV-F80) repair or replacement part needed
    This JVC parts supplier may have what you are looking for. The description appears appropriate, but the part numbers don't match.
    PlainBill
    • ceramic
      • Feb 2009
      • 11
      PlainBill
      Thanks for the link. Looks like that will work.
      Before I consider buying it though I want to be sure the problem is the pick-up lens. Could the problem be from any other source?
      • Toasty
        • Jul 2007
        • 4171
        >>Could the problem be from any other source?<<
        Absolutely it could. If its playing CD's (you do mean VCD's, correct?) but not DVD's, I doubt very much the problem is a broken optical pickup. (@ $75 a pop)
        It may be that the pieces hit the pickup and knocked it out of alignment. If that's the case, you will likely need to send/take it to a repair facility that has the equipment to realign it.
        What in blazes caused a DVD to shatter INSIDE the player??? They're difficult enough to break OUTSIDE, so what happened in there? These mechanisms are ~usually~ set up to detect a jam and go into reverse to remove the problem. The force required to break a DVD probably broke or severely damaged some part of the drive mechanism.
        I would be looking for a damaged drive wheel, broken gear(ing), bad motor, bent or broken "something".
        Toast
        veritas odium parit
        • G-Sting
          iPad Pro A1876 SHORT Part Identify Help Needed
          by G-Sting
          So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
          So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
          i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
          SO My main concern is what part should i order what should i search the name for ?
          on Ipad...
          05-15-2025, 09:30 AM
        • the_rem
          Unknown transformer : how to find a good replacement part ?
          by the_rem
          Hello guys,
          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
          04-23-2025, 01:48 AM
        • edugimeno
          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
          by edugimeno
          Hi There!
          I'm trying to help my friend who owns a restaurant be just bought.
          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
          It's stuck using, I guess, the 2 sided tape that comes with the strip
          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
          09-05-2024, 09:34 AM
        • Cvrado
          Led TV Board Replacement, same part number and model, different size
          by Cvrado
          Hello my friends!
          I have a question that I think you can answer and help me with!
          I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
          So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
          My concern is that the board won't draw enough voltage to the bac...
          03-02-2024, 05:05 PM
        • RyanRiz
          Asus ROG STRIX G512LW-WS74 needed clearME bios after PCH replacement
          by RyanRiz
          Dear All,
          I need assistance creating clearMe bios. The laptop is shorted PCH, after PCH replacement laptop can ON but cannot boot. Power supply current reading is 2.5-3.0 Amp.
          Model : G512LW-WS74
          SN : LCNRKD009429512
          CN : ANE9
          Attach backup bios.
          Thanks for your help.
          Best Regards....
          01-14-2025, 05:55 PM
