Samsung UE55F6800SB
  • ronhayes
    TV Engineer
    • Mar 2014
    • 458
    Re: Samsung UE55F6800SB
    This is the label on the LCD panel
    • ronhayes
      TV Engineer
      • Mar 2014
      • 458
      Yes UE55F6800SBXXU
        Samsung P/N for your panel is BN95-01193A.
        • ronhayes
          TV Engineer
          • Mar 2014
          • 458
          Any help locating this board would be much appreciated ?
          I have checked Ebay and shop Jimmy all with no success i found a site called TVserviceParts they had one but you could buy a couple of replacement TV,s for what they were asking for the board !! crazy.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #85
            Morning ron I have had a search on various sites and can not find the tcon this usually means it a common failure item so maybe a waiting game for one too come available in the meantime it maybe advisable too try and fault find your old tcon and see if you can find why its causing a boot loop situation maybe its just a shorted cap or faulty regulator etc not sure if tcons have eeproms on that could cause this fault?
            • zomi
              • Nov 2011
              • 505
              #86
              https://www.ebay.co.uk/itm/SAMSUNG-U...4AAOSwAqFbrOa5
              or
              https://www.ebay.co.uk/itm/BN41-0193...IAAOSws-tbJbFT
              do these 2 not matchup
              they are from 55f6800sb from the description
              Ask the sellers to confirm the info you need
              I dont think this tv had different panels so as long as they are from the right tv the should work
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #87
                cy-gf550cslv9h is this the correct lcd panel number? im on my phone so hard to see
                these seem too offer a repair service at a good price maybe worth sending them a email and see if there repair service fixes the boot loop issue
                https://www.tvparts.co.uk/lcd-tv-spa...800sbxxu-ver10
                Phone:01246 250678
                Email:info@emos-tvs.co.uk
                • ronhayes
                  TV Engineer
                  • Mar 2014
                  • 458
                  zomi thank you i have contacted one of them just waiting for a reply the other one listed with emos i had contacted them a couple of days ago they did not have one in stock.
                  Vince sorry late getting back to you went to collect some medicine .
                  Thank you for that info i have phoned them they do not have one in stock and when i explained the issue and that when i tried another board the TV stayed on but with my board it was tripping even when ribbons to lcd panel removed either both or one at a time and did not reboot loop with ribbon from main board disconnected . I told him i had tried another board although not the right one he agreed it does appear to be a T-Con board fault, They had not had to carry out that fault before but if all failed i could send it to them and they would have a look. But he said if i clicked on notify me when in stock they have a good turn over and it would stand a good chance with in a week but no promises .
                  • ronhayes
                    TV Engineer
                    • Mar 2014
                    • 458
                    I have used my MS8910 smd tester on most of the smd caps and resisters in the auto range non have come up as short but not knowing all the values it is hard to carry out an accurate test ?
                    • ronhayes
                      TV Engineer
                      • Mar 2014
                      • 458
                      budm
                      You said that the T-Con board i required was BN95-01193A.
                      But on the label of my T-Con the BD number is BN95-01134A.
                      Do you think that may be this had been changed in the past and the wrong board fitted? or is this number compatible ?
                      • ronhayes
                        TV Engineer
                        • Mar 2014
                        • 458
                        I apologize to any one if i appear to be pushy with this repair but i am due to go in hospital early November for 4 weeks for my stem cell transplant and will be very poorly for a few months so wanted to sort it out hopefully before then .
                          Originally posted by ronhayes
                          budm
                          https://www.badcaps.net/forum/attach...5&d=1538434946
                          Your panel P/N is BN95-01193A as you can see in your picture of the LCD panel sticker.
                          https://www.badcaps.net/forum/attach...9&d=1538484737
                          T-CON board P/N is BN95-01134A as shown in your picture.
                          • ronhayes
                            TV Engineer
                            • Mar 2014
                            • 458
                            Sorry budm
                            Thought you were saying i needed BN95-01193A p/n for my T-Con board.
                            Some times i don't see the wood for the trees silly me
                              You need to ask them if BN95-01134A is the correct P/N as printed on the sticker, also show them the pictures of the board.
                              • ronhayes
                                TV Engineer
                                • Mar 2014
                                • 458
                                Yes i will thank you
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #96
                                  did you manage to find a replacement board ron lets hope the replacement fixes the issue
                                  • ronhayes
                                    TV Engineer
                                    • Mar 2014
                                    • 458
                                    Morning vince and all
                                    Update for this TV i managed to locate a T-Con with the same numbers as mine
                                    LSF550H J03 BN95-01134A. From Spares2Repairs for £24.00.
                                    Now the TV comes on in St/By when you press power button on remote and it stays on, it does not go off/on repeatedly as it did with my original T-Con.
                                    But i still have a issue with the picture as you will see from the photo's included.
                                    I have carried out all tuning to the TV and have even connected it to the internet and all works fine.
                                    The picture is a nice picture as you can see in the photo's but for these lines more prominent on a lighter screen. I have tried altering the settings in display menu but can not loose the lines ?
                                    Does any one have any idea what is causing this issue ?
                                    Or maybe i need to go into a service menu to set it up ? any ideas would be much appreciated.
                                    • ronhayes
                                      TV Engineer
                                      • Mar 2014
                                      • 458
                                      I have now changed back to my original AV main board to see if that would give me any better results ?
                                      But still the same ?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #99
                                        thats a odd fault maybe check/clean the cables going from the mainboard to tcon and also the ribbon cables going too the panel pcb from the tcon. I wonder what that tcon board fix on ebay i sent you the link for, does that fix solve the lines issues? maybe worth messaging that person and include a picture for them too see.Now you see that both mainboards are working ok you could probably re sell one if you wanted too get some money back.
                                        • ronhayes
                                          TV Engineer
                                          • Mar 2014
                                          • 458
                                          I have just gone into a self diagnostic menu where you can carry out a test on picture ,sound etc.
                                          Take a look at these photo's and see what you think. I think the photo display still shows the lines but the colour pattern test looks to be better display ?
                                          Who agrees? I answered yes to the first question (can you still see the problem in this test photo ) And then answered no to the next question fort displaying the test card (can you still see the problem in this test photo )
                                          Then it displays a screen saying please contact the Samsung call centre .
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
